Page 2 of 2
Re: Cooling pressure test kit anyone?
Posted: Wed Mar 10, 2010 12:17 am
by jumper
he uses the 2 systems, the pressure test to test the system and the vacuum to refill
Posted: Wed Mar 10, 2010 8:28 am
by falcoron
How does that work when you need the stat to open? shoot me if im thick!
Re: Cooling system pressure test kit anyone?
Posted: Fri Nov 23, 2012 8:11 pm
by Driver+Passengers
DO NOT DELETE?
Edit: Sorted
Posted: Fri Nov 23, 2012 8:57 pm
by Bogmonster40
excellent post, u could not have made it any easier.....
Re: Cooling system pressure test kit anyone? DO NOT DELETE
Posted: Fri Nov 23, 2012 11:11 pm
by Toby&Jules
Indeed. Ours is still hibernating, but the more I read, the more paranoid I get about leaks. I just want Bongo ownership to be a happy experience for us both. Definitely gonna be doing this shortly.
Regards
Toby
Posted: Fri Feb 01, 2013 12:23 am
by Northern Bongolow
a spin on this tester is to put the gauge in line and use a flat cap to test.
put the gauge on a t piece, then put half the pipe on either side of the t piece, then get a standard cap and remove the seal, this gives easier pressure readings.
when your happy with it you could fit it to the end of the bleed pipe, then put the gauge in the cab, then you have constant pressure monitoring.
Posted: Fri Feb 01, 2013 11:55 am
Northern Bongolow wrote:a spin on this tester is to put the gauge in line and use a flat cap to test.
What, so you look like Fred Dibnah while doing it?
Posted: Fri Feb 01, 2013 7:52 pm
some would say i dont need the cap to do that matt.
ps. have you got a light for this woodbine
