Re: Cant find the problem....pls help !!!
Posted: Tue Feb 23, 2010 2:36 pm
Could it be one of these pulleys you are looking at?
A forum for Bongo fans and owners
https://igmaynard.co.uk/bongo/forum/
This any good?FREDA MIND wrote:hi guys, interesting thread,,, ive got to change the water pump in next few days, how tight do the aux drive belts need to be???
cheers ricky
Sounds like the crank pulley is brokenthe guvnor wrote:I have investigated more in daylight lol...........hope you slept widdowson
ok so i was sort of correct in what i rememberedthe 'loose' pulley i refer to sits directly behind the crank pully ! this is were the drive belts sit, it is seperate to were the belt for the air con sits and it does not obviosly move wen the belts are on because of the pressure but with no belts it seems to slide freely from side to side. after looking more closely and adjusting/ loosening a few belts i may have cured the main noise
will now more when i start her from cold (sounded like a bag of bolts this morning !!!!) but i still have a sound that i hope resembles tappits. Looks like it could be the next job on the list !
Still not sure if the said pully is meant to be like it is though !!!!!!!
thanks widdowson thats just what i was looking for , thankyou v muchwiddowson2008 wrote:This any good?FREDA MIND wrote:hi guys, interesting thread,,, ive got to change the water pump in next few days, how tight do the aux drive belts need to be???
cheers ricky
I would agree with Dandy,could be the Harmonic Damper has parted company.dandywarhol wrote:Sounds like the crank pulley is brokenthe guvnor wrote:I have investigated more in daylight lol...........hope you slept widdowson
Still not sure if the said pully is meant to be like it is though !!!!!!!![]()
Is it item 11-371? http://www.lushprojects.com/bongopartsm ... mgno=.html
