Page 2 of 2
Re: scavenger fan sensor
Posted: Thu Jan 21, 2010 10:37 am
by mikexgough
helen&tony wrote:Hi
I test the scavenger fan every spring. First pull the connector off the sensor and short the connector...fan works. Next, connect it back up and play a salon type hairdryer on the sensor...when its hot ...fan works. It rarely switches on, and it only kicks in here after the car has been parked for 10 minutes in summer when the air temp is around the mid 40s plus. If you leave the car parked for 20 mins/ 1/2 hour, the engine cools a bit, heat is lost from the engine compartment , and it won't kick in.
The answer...you're unlikely to hear it, because it hardly ever works
I agree....... the test once a year is a a well worth check........ and again I second the comment about how little it operates....
Worth a check to see if all is well before wasting money on bits n bobs you don't need...
Posted: Sat Jan 23, 2010 1:05 pm
by dandywarhol
berrega wrote:Well that's usefull, because bongobits.com want £80 for the sensor when you can get them for £16.99 from ignitioncarparts.co.uk
I'm not paying £60 for a small bit of plastic when I dont even know whether my current one is faulty or not...
Good find - also makes sense - both measure air temperature. BUT, if it is the same switch..........it also means that the engine bay sensor isn't a simple on/off switch (something I've been bleating about for a while now
) - its giving a signal to the ECU of a varying signal for the ECU to decide when the auxiliary fan cuts in. Thats why people get different results when disconnecting/flashing the sensor over a variety of ambient temperature ranges. The auxiliary sensor swich works in conjunction with the coolant sensor according to what I can make out in the manual - and why I don't go down the route of bypassing it to manually switch it on............................................
Posted: Sat Jan 23, 2010 2:10 pm
by mikexgough
dandywarhol wrote:berrega wrote:. BUT, if it is the same switch..........it also means that the engine bay sensor isn't a simple on/off switch (something I've been bleating about for a while now
Exactly my thoughts....
..... we shall find out the absolute on that theory when the ECU work has been done...... if it comes out how I think it will
................ it will put to bed the need to bypass or to install any device or switch to override the ECU and switch on the fans
Posted: Sat Jan 23, 2010 8:49 pm
by Rhinoman
We should be able to tell from the schematic if its a thermo switch or a thermistor.
