Re: air conditioning
Posted: Mon Jan 11, 2010 2:41 pm
Yup, got that but the way I see it we're talking about ambient air being drawn in from the outside via the intake. It either is (cold dry air) or gets dehumidified, and maybe warmed, then blows on the windscreen and evapourates anything there, then mixes with the moist air occupants are breathing into the cab, making the mixed air mass dryer through dilution and aiding evaporation on passenger/rear windows. Then, in theory, it leaves via the exit vents towards the rear of the vehicle.francophile1947 wrote:It's true that you don't need the aircon in sub-zero conditions except you're forgetting one thing Mike - you breatheBreathing pumps loads of moisture into the air in your Bongo - this condenses on the cold windows (or it does in mine
If you go on recirculation, its a different matter as the aircon has to be successful at dehumidying all the moist air being breathed by occupants as the condition of the outside air doesn't figure.
