i got everything i needed in my kit... the only thing you may need to add depending how you wire the + wire is an inline fuse/holder... it realy is very simpledandemann8 wrote:Would I require anything else to go with this kit ( not technically minded )joe-robo wrote:http://cgi.ebay.co.uk/UNIVERSAL-REMOTE- ... 53d8e02aaf
this was the kit i used, you would only need to fit the master, all the wiring is done, the only thing you have to do is conect the + - leads....![]()
or are there better options out there
Duncan.
your other options is to have an alarm fitted which can be linked to the central locking, microscan make a very good one that does it for about £80...
