Re: Rear drop link's
Posted: Sun Nov 01, 2009 6:02 pm
But....but.....but.....Miss......please Miss.......won't water based get washed out with all the water on the road please Miss?missfixit70 wrote:As you say Mike, probably as well to replace the ARB bushes & brackets too if you haven't already,for the sake of £20 or so for the bits, while it's in the air & you're underneath with the tools, you know it's done then![]()
Give the nuts a good soak with plusgas or penetrating oil the day before & again make sure the bar is clean with no horrible rusty bits & now you can use your water based lube - not petroleum based Mike![]()
