Re: Switch ! What is it ?????
Posted: Fri Oct 16, 2009 11:47 pm
Parking pole is the corner guide
A forum for Bongo fans and owners
https://igmaynard.co.uk/bongo/forum/
missfixit70 wrote:Parking pole is the corner guide
There was a rocker switch on my sisters freda that when switched either illuminated the factory cibies on the bullbars, or the factory fogs in the bumper...Both sets couldnt be illuminated at the same time, either one or the other via the rocker switch (the rocker only came into play if the main front foglight switch was enabled).mister munkey wrote:Mine had something like that.
I think it used to have bullbars & spots in its Japlife but it came over here without. Only bothered to trace the old wiring down to the front end after fitting my own bars & spots though.
already have a switch for the front fogs.missfixit70 wrote:The wiring & plug could be the loom for front fogs?thedogsbollox wrote:I found one whilst fitting my Low Coolant Alarm. On the right hand side beside the Corner guide switch. There is a switch blank there but behind there is a plug and wiring. Couldn't figure that one at all. Also when i removed the panel under the steering wheel, stuck to the back of it was a small black box about the size of a ciggy packet, whats that?
Stick a photo of the box up, could be a turbo timer mebe? any switches or anything on it?
Is your speedo chipped ?thedogsbollox wrote:already have a switch for the front fogs.missfixit70 wrote:The wiring & plug could be the loom for front fogs?thedogsbollox wrote:I found one whilst fitting my Low Coolant Alarm. On the right hand side beside the Corner guide switch. There is a switch blank there but behind there is a plug and wiring. Couldn't figure that one at all. Also when i removed the panel under the steering wheel, stuck to the back of it was a small black box about the size of a ciggy packet, whats that?
Box has no switches. Just about 12 wires going into it.
@ borobongo. There already is a parking pole switch too
