Electric folding mirrors blowing fuse 8
Ron Miel
Re: Electric folding mirrors blowing fuse 8
Post by Ron Miel » Wed Sep 23, 2009 12:05 am
Border T wrote:Hello Ron, just to let know that ive just had problems with mirrors not working along with all other items on fuse 8.It had me stumped for some time until I moved the stearing column position and the mirrows then kicked back into life again ?? It appears that when fitting my cruise control I had either loosened a plug connection within the stearing cowling or trapped a wire when adjusting the column position..If your fault re appears remove the stearing cowling cover and check plugs and cables for damage etc...
Thanks Border T. It wasn't that, this time at any rate, as the problem occurred before I started the cruise control install. I had the partially cruise-installed motor all put together and back on the road today, and all systems were go. Might well bugger it up again though, doing the final wiring up tomorrow - after an absolute pig of a job getting the servo and throttle control parts shoehorned into our LPG-V6 :(
