petrol guage / fuel gauge
dblake
Re: petrol guage / fuel gauge
Post by dblake » Sat Feb 16, 2013 12:08 am
Richard hird wrote:Well done everybody and thanks for all the help. I did the magic earth, this didn't work. I took the sender unit out and cleand it, that didn't work. Thought about buying a new one (£178 del.), too much so that didn't work. Thought about second hand one (£80 del). Far too much so that didn't work. HIT THE TANK WITH A RUBBER MALLET A FEW TIMES. THAT REALY WORKED. So I think all in all the earth the clean and the whack all helped to resolve. Thanks again for all the help, weldone. =D> =D> =D> =D> \:D/ \:D/ \:D/ \:D/ :D :D :D :D
Sorry to resurrect this thread but i've just done the external earth (tank to chassis) fix and not had any joy in getting my fuel gauge to respond :(
So before i attempt to take the carpets etc up - just whereabouts did you hit it with the mallet and how hard? [-o<
the laird
Post by the laird » Sat Feb 16, 2013 8:19 am
If you gently hit the underside of the tank in the middle and give it a few hits around and about
daveblueozzie
Post by daveblueozzie » Sat Feb 16, 2013 9:31 am
Make sure that you have contact with bare metal on the chassis and the tank, scrape off any rust,underseal to expose the metal.
Lost without my Bongo.
chris30taylor
Post by chris30taylor » Tue Feb 19, 2013 4:08 am
I recently did mine. There is a great piece of earthing metal plate just behind the spare wheel. I thorougly cleaned it with a piece of wire wool, set up the wire with ring connectors and washes to make as much surface area as possible, and connected the other end to the nearest hole on the tank lip. This I also made sparkling clean. When I initially turned the key I thought it hadn't worked but then the dial started to creep up and has worked since. =D>
