Page 2 of 3
Re: lowered rear axle alignment out!!!
Posted: Sat Aug 22, 2009 11:53 pm
by cheffy34
dandywarhol wrote:The Great Pretender wrote:testrun00 wrote:Oh definitely the way to go is an adjustable panhard after all I'm not racing or welding new mounting points for a panhard
I just want my rear axle centred then I can sort out my tracking and go in a straight line
Then your missing the point, let me do a simple drawing with a compass and get it up on here so you can see why it wont go straight.
Will it then point North???
Depends if he drops it
Posted: Sat Aug 22, 2009 11:57 pm
by The Great Pretender
Ok, the arc on the line has the least lateral movement, now look at what happens when you lower the mounting point. I'm trying to keep this simple Dandy to make a point about axle movement.
Posted: Sun Aug 23, 2009 12:04 am
by cheffy34
The Great Pretender wrote:Ok, the arc on the line has the least lateral movement, now look at what happens when you lower the mounting point. I'm trying to keep this simple Dandy to make a point about axle movement.
So does that mean it will roll more or bounce more
prob dumb i know mr P
but i am a chef
Dar
Posted: Sun Aug 23, 2009 12:10 am
cheffy34 wrote:The Great Pretender wrote:Ok, the arc on the line has the least lateral movement, now look at what happens when you lower the mounting point. I'm trying to keep this simple Dandy to make a point about axle movement.
but i am a chef
Dar
It will cook your tyres as they will scrub more (be pushed/pulled in and out a bit like the Hokey Cokey)
Posted: Sun Aug 23, 2009 12:14 am
by dandywarhol
TGP is spot on with the theory but if you fit shorter springs then it will raise the axle point - and if the standard setup has the chassis point higher than the axle then fitting lower springs would bring the panhard rod to more horizontal
- I'll have a look in the morning at where the standard setup lies in relation to the chassis point - interesting thread
Posted: Sun Aug 23, 2009 12:16 am
by cheffy34
Ahhhhhhhhhhhhhh thankyou
I know a couple of scrub####, if i wrap them around my wheels will they go further
so i take it if my rear tyres are good and i not had a prob with excessive wear then i should be ok
I agree with dandy interesting
lets see how long before i get confused
was always better with me hands
Dar
Posted: Sun Aug 23, 2009 12:32 am
by testrun00
So what your saying is right then adjustable panhard is the way forward, 1: it will centre my axle 2: my arc will be smaller so less cooking on those tyres.
Or have I misunderstood you.
Posted: Sun Aug 23, 2009 12:35 am
dandywarhol wrote:TGP is spot on with the theory but if you fit shorter springs then it will raise the axle point - and if the standard setup has the chassis point higher than the axle then fitting lower springs would bring the panhard rod to more horizontal
Like I said Dandy I was trying to keep it simple to show how the arc changes related to axle movement. If we start talking about if the pickup point is at the roll centre point and its affect or relation to suspension design everyone is gonna fall asleep.
Posted: Sun Aug 23, 2009 12:39 am
testrun00 wrote:So what your saying is right then adjustable panhard is the way forward, 1: it will centre my axle 2: my arc will be smaller so less cooking on those tyres.
Yep your right, you have misunderstood me.
Posted: Sun Aug 23, 2009 12:40 am
by cheffy34
Posted: Sun Aug 23, 2009 12:48 am
Whats new....................
by missfixit70
I've been trying to keep up with this one, but meds fuddling my brain are just not helping, I'll try again another day
Posted: Sun Aug 23, 2009 12:51 am
Posted: Sun Aug 23, 2009 1:58 pm
by volamoose
Hmm I used to fix bits of machinery so thought I would get this one, but no I'm lost. However, I have just had the bingo, bango lowered by 40mm with the springs from bell hill. I feel like the handling has improved and I don't have a pull to the right. Does this mean that all is well and these problems only occur if you have your van lowered beyond a certain point, or is it just happening to a lesser extent?
Posted: Sun Aug 23, 2009 2:09 pm
by testrun00
The reason mine is pulling to one side is cos I had the tracking done while the rear axle is out of alignment. They tracked the front wheels from the rear ones, cos the rear is out the front is now out
