mikeonb4c wrote:francophile1947 wrote:I've never tried K Seal, but I've used Radweld and Bars Leaks with no problems - not for many years though. They certainly didn't block anything apart from the leak they were supposed to. If memory serves me correctly, they shouldn't set unless exposed to the open air.
I guess its one of these tricky areas. Were the pipes on the ones you tried it on in better nick (no furring) or maybe of bigger bore (older technology) than this particular Bongo. Who knows. But clearly the stuff can't be causing bad side effects on a regular basis or it'd be a banned substance
Defo older technology Mike, but not much
I put some Bars Leaks in a J reg Fiat Uno 1.7 diesel, that developed a slight crack where the top pipe was welded into the radiator, whilst on the way to Dover. It was intended as a temporary fix, so that I didn't miss the ferry to France - 3 years and over 40,000 miles later (with the help of a blob of Plastic Padding
) it still didn't leak when the car was traded in
