Cube battery charging problem !!
Gerriatric
Re: Cube battery charging problem !!
Post by Gerriatric » Sun Jul 12, 2009 1:27 pm
Just opened a Photobucket account and so here's my first pic which might help explain my earlier postregards cube relays.
Gerry.
Rhod
Post by Rhod » Mon Jul 13, 2009 10:26 pm
Gerry
If you PM me your address, then I can post you my spare relays for you to plug in. They are both OK, so if switching them doesn't solve the problem then at least you've eliminated the relays as an issue.
Rhod
Gerriatric
Post by Gerriatric » Tue Jul 14, 2009 9:36 am
Rhod,
In Compose a PM I selected your details from the address book, but it doesn't seem to go when I press "Submit".
Am I doing something wrong? This is the first PM I have tried.
Gerry
Gerriatric
Post by Gerriatric » Tue Jul 14, 2009 3:36 pm
Hi Rhod,
I put a post on Admin to get guidance on sending PM's and suddenly the penny dropped on what I was doing wrong. ie: I didn't click on the PM button on your post!! :oops: :oops:
At least it's now in my Outbox, so hopefully you can now see it.
Regards
Gerry.
Rhod
Post by Rhod » Tue Jul 14, 2009 11:16 pm
PM received & reply sent!
Rhod
Post by Rhod » Wed Sep 16, 2009 8:02 pm
Hi Gerry
How are you getting on with your Cube charging problem?
My own battery doesn't seem to want to charge properly at the moment. I fear that I may need to replace some relays! Any chance that you could post back the used relay of mine & the bits of your broken relay so that I can try to source a replacement?
Many thanks
Rhod
