apole wrote:Hi,
Just fitted mine. As others have said it is really very simple. All you need is a crosshead screwdriver, lower the steering wheel to it's lowest position, disconnect the battery, then remove the 4 upward facing screws that hold the cover to the instrument binnacle on.
You need to carefully pull and prise this out. On mine I have a couple of extra switches, as well as the fog light. The cables for these were tight. On one side there was no easy way of disconnecting the switches so I took off the wiring to the fog light etc on the RHS. As mine was a retrofit I had to remove 3 wires from this, remember to label them if there is any danger of mixing them up when reconnecting.
I then swung the cover around over the gearstick. You will then see the instrument cluster being held in by 4 horizontal facing cross head screws. Remove these.
Then pull forward the binacle, I had enough slack in the wires to pull it out and twist is round to gain access to the rear RHS of it where you need to wire in the 3 wires to the mason alarm as per the instructions. Be careful not to remove the screws too much or short circuit any of the copper connectors with the mason connectors. Don't overtighten either.
Then reconnect the battery, turn on the ignition, you will hear a chirp, that's it. Put the mason alarm back in to the dash, and thread it and it's wiring back and down so when you put the binacle back in no wires will be trapped.
There's enough slack in the alarm wiring to route it down, then up the side of the dash leaving it resting on top so it can be adjusted until it's right.
I have a several journeys over the next few days to get this adjusted.
Keep you posted but impressions are good, well made, good price, arrives quickly and easy to install.
Andy
Fitted mine ages ago apole
Dar
