How Many Volts
Re: How Many Volts
Post by haydn callow » Fri May 29, 2009 3:49 pm
That does seem low and I agree a new battery could sort it...The LCA seems to detect this.
Re: How Many Volts
Post by mikeonb4c » Fri May 29, 2009 5:05 pm
ex25er wrote:I know you've got what you need, but mine was 13.8
When i turn my ignition on my lca slowly fades out in a kind of wimpy strangulated bleep sound, rather than a good 'manly' BLEEP. It also occasionally lets out a little chirp just after starting up.
Could it be my battery has seen better days? It wouldn't surprise me if it had, it's japanese and the bongo's been over here for about 3 years now I think.
Phil
Just did mine (finally remembered!) at tickover, fans+aircon switched off, and I'm relieved to read your post Phil. I got 13.8v too. And just as a reminder of how questionable the accuracy of voltmeters just slapped on elsewhere with a bit of wiring can be (not bothered t test if its the device or wiring issues), my DIY panel mounted one, taped off the LB, only showed 12.37v at the same time. Oh well, at least it tells me if my VSR is kicking in OK after start up, plus an indication of state of LB in use. Plus it looks the biz. 8)
dandywarhol
Re: How Many Volts
Post by dandywarhol » Fri May 29, 2009 5:50 pm
If 13.8 is the charging voltage - you need to see whats in the battery with the engine (and everything else off) before you condemn it. It may be the alternator not producing the correct output!
Only proper way to check the battery is to use a hydrometer in each cell once fully charged and a small amount of surface discharge is taken off by switching on headlights for about 5 seconds with the engine off.
Re: How Many Volts
Post by mikeonb4c » Fri May 29, 2009 9:09 pm
dandywarhol wrote:If 13.8 is the charging voltage - you need to see whats in the battery with the engine (and everything else off) before you condemn it. It may be the alternator not producing the correct output!
My thoughts too, though I'm happy to assume my batteries (esp the starter one) are fine so maybe the alternator isn't working as well as it could/should (lets face it unless you happen to test, the first you know of it is when the dash warning light comes on showing its kaput). Out of interest, what would casue an alternator to be fine but down on output? Or have we by chance got a load of test 14.2v figures off N Japan Bongos (assuming they have a beefier alternator)?
Re: How Many Volts
Post by francophile1947 » Fri May 29, 2009 9:11 pm
mikeonb4c wrote: Or have we by chance got a load of test 14.2v figures off N Japan Bongos (assuming they have a beefier alternator)?
Afraid not Mike - mine's a non-winter jobbie.
Re: How Many Volts
Post by haydn callow » Fri May 29, 2009 9:47 pm
Any battery depot will "drop" test your battery for you FOC
dandywarhol
Re: How Many Volts
Post by dandywarhol » Sat May 30, 2009 12:10 pm
A diode could be fault- you can usually just buy a diode pack. Shouldn't matter whether the vans from north japan or timbuktoo - the regulator will still regulate to a set voltage
Re: How Many Volts
Post by mikeonb4c » Sat May 30, 2009 12:19 pm
dandywarhol wrote:A diode could be fault- you can usually just buy a diode pack. Shouldn't matter whether the vans from north japan or timbuktoo - the regulator will still regulate to a set voltage
Thanks Dandy. Interestingly, I have Harry's old alternator (not that old - it was only used for 9 months) that I bought off him, so might sneak a peek at that. Is the diode pack housed in the main alternator unit?
Bored Lizard
Re: How Many Volts
Post by Bored Lizard » Sat May 30, 2009 6:32 pm
Haydn,
Sorry for the delay mine is 14.36v with a calibrated meter and everything off, hope this is of help.
Did also discover that my split charge fuse is blown so now need to investigate, lesure battery reading 10.02v and the radio etc still working, looks like a job for sunday.
Mark
ex25er
Re: How Many Volts
Post by ex25er » Sat May 30, 2009 6:57 pm
hmm... mentioned it to neighbour who's an RAC man. He reckons that 13.8 is ok. On the lower side of ok, but ok still and not to worry about it. He reckoned 13.5 - 14.5 was pretty normal. Anything less than 12 and you've definitely got a problem!
I'll just leave it as it is for now I think!
Phil
dandywarhol
Re: How Many Volts
Post by dandywarhol » Mon Jun 01, 2009 1:00 am
A leisure battery automatic split charge relay would have problems operating at 13.5v :?
BongoMTBer
Re: How Many Volts
Post by BongoMTBer » Mon Jun 01, 2009 7:15 am
dandywarhol wrote:A leisure battery automatic split charge relay would have problems operating at 13.5v :?
Mine never goes above 13.9 volts and whenever I am running the cool box with then engine running, the split charge relay clicks in and out every 10 or 15 seconds. :?
The leisure battery is fairly new and when it charges off my mains charger on hook-up it goes to around 14.2 v.
I wonder if it is the main battery or the alternator that is dragging mine down? It certainly is causing issues with the split charge though. I will have to try starting the engine and then disconnecting the battery with the engine still running and test the alternator output.
Re: How Many Volts
Post by haydn callow » Mon Jun 01, 2009 8:40 am
I always test my alternator output at the alternator.
phedders
Re: How Many Volts
Post by phedders » Mon Jul 27, 2009 1:13 pm
haydn callow wrote:
Bored Lizard wrote:Haydn,
Will check tommorow now that I have my calibrated meter back from work and will let you know readings.
Am interested to know why you want to get a reasonably accurate average tho.
Mark
We are Looking at a future new circuit design for the Bongo LCA.
Just curious what the voltage window is.
Seems to be about 14.1v to 14.7v
I think we have what we need now......BIG thanks to all of you.
Will you tell us what you modify? My LCA does twitter and chirp every now and then... and if you've worked out a sensible tweak or two I'd love to modify mine..
Location says where I am... I'd rather be justabout anywhere else! Suggestions or job offers of/in other parts of the UK gladly received...
Re: How Many Volts
Post by haydn callow » Mon Jul 27, 2009 1:45 pm
Mark
If your LCA "twitters and cheeps" it is almost certainly caused by a loose connection in the LCA wiring or a voltage fluctuation in your Bongo.......LCA's either work or not.....the only fault ever to come to light with the LCA's is a batch of faulty buzzers which got through the net.....If one of these turns up....your buzzer will die but the LED will work perfectly....all reported faulty Buzzers have been/will be instantly replaced with new units.
