Radiator Blocked
Re: Radiator Blocked
Post by missfixit70 » Thu Apr 30, 2009 7:21 pm
That's fairly well gummed up then :shock: Good shot of the oil cooler too, might have to pinch those photos :wink:
Mike Jill and Emily
Post by Mike Jill and Emily » Thu Apr 30, 2009 8:09 pm
Help yourself to the photos Kirsty.
For anyone that has not seen the oil cooler it is a hollow tube :shock: Not sure how to describe it really - think of a really wide wedding ring with a hollow band - the oil is fed through the band from one end to the other
A picture is worth a thousand words (especially when they are mine :lol: )
Post by missfixit70 » Thu Apr 30, 2009 8:12 pm
=D> It's just a completely clear tube then, no fins or anything inside?
Mike Jill and Emily
Post by Mike Jill and Emily » Thu Apr 30, 2009 8:29 pm
Perfectly clear end to end - like a telescope with no lenses
jaylee
Post by jaylee » Fri May 01, 2009 8:22 pm
Interesting pictures there..
So.. There's a cavity in the pipe then..? looks quite narrow, i was expecting an Archimedes screw set up!
Mike Jill and Emily wrote:For anyone that has not seen the oil cooler it is a hollow tube :shock: Not sure how to describe it really - think of a really wide wedding ring with a hollow band - the oil is fed through the band from one end to the other
Post by missfixit70 » Sat May 02, 2009 4:18 am
Certainly not the most efficient of coolers, be interesting to monitor the gearbox oil temp & see if it'd be advantagous to fit an external oil cooler & stat as Helen has mooted to me.
Post by haydn callow » Sat May 02, 2009 9:29 am
I would have thought that oil cooler would have been better off out of there and in the airfloe ??
dandywarhol
Post by dandywarhol » Sat May 02, 2009 9:37 am
The coolant temp at the bottom of the rad will be a lot less than the oil temp in the 'box. Remember the oil can't be too thick - the torque convertor will only lockup when the oils at running temp (controled by the engine coolant temperature). Sticking the cooler in the airstrem may overcool it. I reckon the designers will have spent a bit of time and research on this one - not often you hear of a faulty/overcooked autobox..............
Post by haydn callow » Sat May 02, 2009 9:47 am
Makes sense.
Mike Jill and Emily
Post by Mike Jill and Emily » Mon May 04, 2009 8:33 pm
Have run to Alton Towers over the weekend - The temp only got to just over half on the gauge (Mason Alarm fitted) even when pushed up some decent hills. On the way back on the M62 from the M6 junction going East the temp only just pushed over the halfway stage on the steepest sections (as opposed to at the top end with the heaters on full and the alarm chirping as per the previous weekend.)
Top result =D>
So for the year we have had the Bongo we were running round with a duff rad - I am sure that had we not had the Mason Alarm fitted we would have fried the engine.
Next job ...... reverse the seats, change the g'box oil and the heater plugs :roll:
Post by mikeonb4c » Mon May 04, 2009 10:14 pm
Mike Jill and Emily wrote:Have run to Alton Towers over the weekend - The temp only got to just over half on the gauge (Mason Alarm fitted) even when pushed up some decent hills. On the way back on the M62 from the M6 junction going East the temp only just pushed over the halfway stage on the steepest sections (as opposed to at the top end with the heaters on full and the alarm chirping as per the previous weekend.)
Top result =D>
Great result - way to go =D> Makes you realise/wonder how many Bongos out there would benefit from a new rad. and thermostat :roll:
