What size to go for for a full size spare?
stilldesperate
Re: What size to go for for a full size spare?
Post by stilldesperate » Wed Apr 01, 2009 12:13 pm
[quote="scanner"]
I would be tempted to have the spare the same WIDTH as the front tyres so as to avoid any steering imbalance - a difference in tyre width on the rear where the wheels are just "trailing" is (IMHO) less likely to unbalance the handling.
quote]
Good point, Scanner. I'd not thought about steering effort with using a rear on the front.
The difference between sizes front/rear is to introduce (AFAIK) some oversteer, the rolling diameter being virtually the same, front to back, on the standard tyres.
I would, however, say that if you suffer a puncture, you should always take care in your driving style when using a spare, if only because it's been hanging under the van for years, condition untested! Use it to get you home/ to the tyre shop!
Must say, there's a lot to be said for running the same size all round :D
SD
"The older I get, the faster I was"
stilldesperate
Post by stilldesperate » Wed Apr 01, 2009 12:14 pm
Sorry, I meant understeer (I think!) :oops:
Post by francophile1947 » Wed Apr 01, 2009 12:34 pm
I'm sure you did :wink: :lol:
Etienne & Katie
Post by Etienne & Katie » Wed Apr 01, 2009 1:52 pm
So i guess i am committed to changing something about my set up.
Do i change the rears to match the 195/70 or change the front to match the 215/70 ?
is wider better?
are 195's up to the traction required?
does it have to be 215/65?, does the extra circumference do any good/bad?
and finally what tyres does everyone like? make model etc...
scanner
Post by scanner » Wed Apr 01, 2009 2:03 pm
Etienne & Katie wrote:So i guess i am committed to changing something about my set up.
is wider better?
If you keep 195/70 on the front it should be 215/65 on the back to keep the diameters within spec.
But if the fronts are more worn than the rears you could change those to 215/70 to match the rears
As Franco says that will result in some gearing up which will slightly alter the accuracy of the speed/odometer (possibly helpful if yours over reads ATM) and could help economy and cruising by reducing revs at any given speed.
scarlet
Post by scarlet » Wed Apr 01, 2009 3:15 pm
Hi Etienne and Katy one question as i've not seen it mentioned on this tread are you 2wd or 4wd because if you are only 2wd 215/70 15's will be ok on the back its just that your speedo will be slightly out as you will be travelling slighty faster.
scarlet
no-one puts 'baby' in a corner
stilldesperate
Post by stilldesperate » Wed Apr 01, 2009 3:25 pm
Etienne & Katie wrote:195 70 r15 front 215 70 r15 rear on my SGL5
It's a 4WD, Scarlet.
scanner
Post by scanner » Wed Apr 01, 2009 4:06 pm
Be fair - the significance of that isn't obvious to most people.
Etienne & Katie
Post by Etienne & Katie » Wed Apr 01, 2009 5:45 pm
Sorry for not making it very clear..... your right. It is a 4WD
Last edited by Etienne & Katie on Wed Apr 01, 2009 5:46 pm, edited 1 time in total.
stilldesperate
Post by stilldesperate » Wed Apr 01, 2009 5:46 pm
Sorry, didn't mean to be obtuse, the SGL3 is 2WD, the SGL 5 is 4WD.
SD
patnben
Post by patnben » Wed Apr 01, 2009 9:24 pm
If you are changing tyres, you would be better off changing the front ones
to 215/70 so same tyres all round with an identical spare. you can then swap
wheels anywhere you want. You may notice a very slight decrease in speedo
indication but you would not have to worry about the Viscous coupling.
I would guess that the majority of members run 215/65 tyres all round and
seem to think it makes no difference or improves the steering. A steel wheel
will do for the spare, cheap as chips if you can find one with a 215/70 tyre.
Etienne & Katie
Post by Etienne & Katie » Fri Apr 03, 2009 9:34 pm
It no longer matters i have just successfully bought a replacement set of factory alloys with 195's all round on evil bay :evil: :D :D :D :twisted:
Very happy that i can get out over easter in Bertie Gumbo !!
to explain ...(my three year old son calls them Gumbo's, and Bertie bus is from Thomas)
ScubaBongo
Post by ScubaBongo » Wed Apr 08, 2009 8:48 pm
Sorry to drag this topic back to life, but.....
If i have a 4wd, with alloy
Front: 195 70 R15 92H
Rear: 215 65 R15 96H
Can I use a 195 70 15 steel?
I'm thinking the answer is "not on the rear, no"
SB :D
stilldesperate
Post by stilldesperate » Wed Apr 08, 2009 8:54 pm
Yes you're OK to use the steel front or back, as far as size goes.
There's only 1% difference, see
http://www.tyresave.co.uk/tyresize.html
SD
scanner
Post by scanner » Wed Apr 08, 2009 9:06 pm
ScubaBongo wrote:Sorry to drag this topic back to life, but.....
SB :D
OK so long as the load index is 96 or more my 195/70s were 97 so OK.
