Page 2 of 3
Re: cigarette lighter sockets - thicker cable
Posted: Sat Mar 21, 2009 2:26 am
by patnben
Quality caravans use a
CLIPSAL architrave
12V flush socket which
can replace the ciggy lighter socket. They are perfectly reliable up
to 10 Amps (120 Watts) continuously. The matching plugs are not
fused and should be fused elsewhere. Small, neat, and easily wired.
Available from most caravan accessory shops.
Shown here:
http://www.towsure.co.uk
Search for
E615
The plug is
E610
Posted: Sat Mar 21, 2009 8:49 am
by moonshine
madmile wrote:rabbitsquasher wrote:you'll know fairly soon if they're up to the job or not! I would recommend 12v outlets for the draw you're requiring, 35 amps is a lot, of course, you may not be actually drawing that much.... I used to be in the trade, I once fitted some ordinary sockets to a Jeep cherokee to run a docs defribulator (did i spell that right?!!) (you know what i meant!) first use made a nice hole in the plastic surround! That was 20A.
It's 12 years ago but the memory has stuck firmly!
Its 35watts - not 35 amps, so in real terms only about 2.9 amps. A compressor coolbox /fridge is not a particularly big power draw, but its better to give yourself more capacity if its not much more money.
Just to add to Madmile's advice, even though the current draw is only 2.9 amps, if the cable run is more than about 1.5mtrs, it is better to use cable with a rating far in excess of 2.9 amps to avoid voltage drop. Fridges in particular are sensitive to voltage drop and many of them will switch off if the battery voltage drops too low. If the cable used is too thin, the voltage arriving at the fridge will be lower than the voltage at the battery, so the fridge will switch off unneccarily.
Posted: Sat Mar 21, 2009 9:13 am
by vanvliet
patnben wrote:Quality caravans use a
CLIPSAL architrave
Shown here:
Search for
E615
The plug is
E610
OK ,this is the sort of thing I will fit but, michty me, these are ugly looking blighters .Is a nice discreet round socket available? Beige and an odd shape does not appeal ( I know that asthetics should not come into it but for me it has to look right or it will bug me)
Posted: Sat Mar 21, 2009 9:56 am
by daveblueozzie
ebay item number, i have these in my bongo. i used 30amp (i think) wire connected to my leisure battery via a seperate fuse box.
370103133182
Posted: Sat Mar 21, 2009 11:16 am
by vanvliet
Posted: Sat Mar 21, 2009 11:36 am
by dandywarhol
Have you tried Dingbro Geoff?
Posted: Sat Mar 21, 2009 12:18 pm
dandywarhol wrote:Have you tried Dingbro Geoff?
Nope ? Quite a few companies turn up with that name ... mainly in Scotland (I wonder what the name means ?).
Posted: Sat Mar 21, 2009 12:31 pm
by dandywarhol
lol - wrong Geoff - I was asking vanvleit
Ding Brothers, originated in Aberdeen
Posted: Sat Mar 21, 2009 1:04 pm
by teenmal
dandywarhol wrote:lol - wrong Geoff - I was asking vanvleit
The firm was started by Dingwall Brothers.
For Fife,,
Kirkcaldy
Address: 5 Merchant Place, Michelston Industrial Estate
City: Kirkcaldy
Post Code: KY1 3NJ
Tel: 01592 654212
Fax: 01592 653989
Email:
[email protected]
Dave Gourlay - Branch Manager
Derek Schofield - Deputy Branch Manager
Ps they are trade only
Posted: Sat Mar 21, 2009 2:20 pm
by vanvliet
Geoff means ' god's peace'
Will check out Dingbro for the socket
Posted: Sat Mar 21, 2009 2:30 pm
Ah ha I must admit I was bemused, but being the only person who signed using Geoff....
Did you know there's even 22 variants of Geoff as well;
Geffrey, Geoff, Geoffery, Geoffroy, Geoffry, Geofrey, Jefery, Jeff, Jefferey, Jefferies, Jeffery, Jeffree, Jeffrey, Jeffry, Jeffrie, Jeffries, Jefry, Jeoffrol, Jephers, Jepherson, Jephrey and Jephry
Posted: Sun Mar 22, 2009 10:42 am
by vanvliet
Posted: Sun Mar 22, 2009 5:26 pm
by daveblueozzie
g8dhe wrote:Ah ha I must admit I was bemused, but being the only person who signed using Geoff....
TALK ABOUT OFF MESSAGE, WAY OFF MESSAGE
Posted: Sun Mar 22, 2009 7:54 pm
by vanvliet
Hey , I found it interesting!
Posted: Sun Mar 22, 2009 8:45 pm
by rabbitsquasher
in that case the ordinary 8a cable with in line fuse with original sockets should suffice... I just rewired mine from the leisure battery circuit in the rear to provide a feed for the bottle warmer for Jackson. Our wild camp in scotland was great, but when Jackson woke at 3am and we needed a warm bottle, having to empty everything from the front to switch the ignition on was a right mission!
