Page 2 of 3
Re: Garage Bungled Installation of Low Coolant Alarm Help Needed
Posted: Thu Feb 26, 2009 12:51 am
by The Great Pretender
NFT, only teasing about your suspension :wink:
:lol: I thought that was obvious as the dampers damp oscillations. :wink:
Posted: Thu Feb 26, 2009 8:46 am
by haydn callow
There is no way that sensor in the tank is becoming exposed with all that coolant.
I'm also wonderind about if it could be a bad connection now as there is a 4 sec delay which would make that unlikely. When you go round a corner and it beeps/flashes ...is it just a quick beep/flash and it is the RED led that flashes (the low water/coolant one ?)
we will get to the bottom of this.
I wonder where they have wired the pos feed from?
Your not coming Somerset way are you ??
Posted: Thu Feb 26, 2009 9:56 am
by haydn callow
Just a idea.......there is a spare orange wire out the back of the display unit.....this is optional for a oil alert......if that is flapping about and touching earth that would be the problem...(no delay in that circuit)....the end should be taped up>>
Posted: Thu Feb 26, 2009 11:59 am
by teenmal
where is the earth wire connection now..
Malc.
Posted: Thu Feb 26, 2009 12:19 pm
by haydn callow
First to come up with the answer wins a BONGO COOLANT TANK DIP STICK
Posted: Thu Feb 26, 2009 12:39 pm
by francophile1947
Through the coolant itself [-o<
Posted: Thu Feb 26, 2009 12:58 pm
by haydn callow
any more guesses ???
Posted: Thu Feb 26, 2009 1:02 pm
by teenmal
haydn callow wrote:any more guesses ???
Aye,its a bummer......Send me my lollypop.
:lol: :lol: :lol:
Posted: Thu Feb 26, 2009 1:07 pm
by bigdaddycain
Is the coolant strong enough? I seem to recall an issue with somebody's alarm prematurely going off as the anti-freeze mixture was weak?
Is the actual alarm part flopping about? I heard of a member recently that tracked down repeated false alarms due to the alarm part rattling about all over the place, a ziptie cured it,though it should have been secured when it was fitted really... :roll:
Posted: Thu Feb 26, 2009 1:12 pm
by haydn callow
Hmmmm!! coolant strength can affect the alarm but not in this way....this is potholes and corners........coolant strength would be when cold and a "chattering noise......If the alarm was flapping about there must have been a loose connection to cause it to play up...the module it'self is pretty bombproof
Posted: Thu Feb 26, 2009 3:46 pm
by New Forest Terrier
Hooray!! :lol: Problem solved thanks to Haydn and everyone. :D The sender on the tank was slightly loose. :evil: Not obvious but a small amount of movement when twisted. Tightening the attatchment screw up cured the problem.
The Bongo has been tested on Hampshire's best potholes, various bends and a rough track and not a beep except for starting up. :D
The temperature readout really shows up how useless the guage is. The range that registers as 11 o'clock is very wide.
Congratulations everyone =D>
Posted: Thu Feb 26, 2009 3:51 pm
New Forest Terrier wrote:Hooray!! :lol: Problem solved thanks to Haydn and everyone. :D The sender on the tank was slightly loose. :evil: Not obvious but a small amount of movement when twisted. Tightening the attatchment screw up cured the problem.
Great news =D>
Posted: Thu Feb 26, 2009 3:53 pm
by haydn callow
haydn callow wrote:Well that's all fine...in fact if that tank is cold you could "suck" a bit out with a syringe.
Next...Is that terminal on the tank tight ?? You should not be able to revolve the terminal on the screw.
Hmmm!!!not bad eh ?? smug look.
Posted: Thu Feb 26, 2009 4:00 pm
by haydn callow
And the winner of the BONGO TANK DIPSTICK is.............
Francophile1947..
Pm your address to claim your prize
Posted: Thu Feb 26, 2009 4:05 pm
Smug look well deserved Haydn =D> . Perfectly diagnosed. 8)
Found it first thing this morning but could not get to the pc until now to tell everyone.
Thanks Again
