Advice required, 4 Wheel Drive Bongos ***DON'T DELETE***
mister munkey
Re: Advice required regarding 4 Wheel Drive Bongos
Post by mister munkey » Thu Feb 19, 2009 11:39 pm
Honest EA, there are no horror stories. I wasn't bothered either way over 2 or 4wd when I went shopping for mine but have been quietly pleased for the occasional benefits the 4wd has given. The most important thing to concerntrate on is the Right One.
As long as its been looked after well, regularly serviced by someone who knows what they're doing, a shoddy looking 2wd may well be a better bet that a shiney 4wd.
Think long term, check history, all will be well.
rustyp
Post by rustyp » Fri Feb 20, 2009 12:22 am
How are 4wd converted to 2WD? Is it straight forwards?
Post by missfixit70 » Fri Feb 20, 2009 12:47 am
rustyp
Post by rustyp » Fri Feb 20, 2009 12:52 am
I can't get onto the factsheet even with my username and password! #-o
MountainGoat
Post by MountainGoat » Fri Feb 20, 2009 5:12 pm
You have to be a paid up club member and receive the password from Ian the bongomeister. The password changes monthly. If you have not received the lastest password then contact Ian.
scanner
Post by scanner » Fri Feb 20, 2009 6:28 pm
Yes - Joining the forum is not the same as joining Bongo Fury and you need to be a paid up member of BF to get access to the factsheets.
Post by bigdaddycain » Fri Feb 27, 2009 10:43 am
This recent thread discussing diffs etc reminded me that i hadn't checked i actually had any diff oil in either of mine! :shock: Nearly 5 years i've been meaning to check it! #-o
So yesterday morning i attempted to scramble under the bongo and have a bit of a rummage...I'd searched the threads on techie for recommended diff oils, and got it down to a short list, dependent on whether my 4wd had limited slip diffs or not.
So objective number one... determine my diff!(s).
Problem number one... I couldn't even fit my head under the bongo, let alone my generously proportioned body (good eh?)... Hmm, how to safely jack the bongo up on loose gravel? :-k
In a moment of inspiration, i solved the problem of jacking my funky baby up!......
:lol: Straight round to wheelquick and let them jack it up instead! :lol:
After myself and stu scratched out heads for half an hour trying to work out how to fit the ramp legs under the bongo, (we used two trolley jacks at the rear, then chopped two big blocks of wood for the legs so my sideskirts didn't get squashed) We determined through spinning of the wheels, that the opposite wheel span the other way to whichever wheel we turned, so it was an open diff, and not a LSD type diff, despite the sticker on the diff casing having the famous "LSD diff oil only" quotation! [-X
Thankfully, both diffs were full to the brim with oil, and both were spotlessly clean, so an executive decision was made not to fix what ain't broke, and back on went the diff plugs.
Can i just take this opportunity to thank my bongo for not being broke! =D> =D> =D>
(she knows if she starts playing up its' bye bye time) :lol:
