does your horn need to work to pass a mot
Re: does your horn need to work to pass a mot
Post by missfixit70 » Mon Feb 09, 2009 9:23 pm
My 95 it's on the driver's side.
Post by bigdaddycain » Mon Feb 09, 2009 9:37 pm
I think you are correct. My bongo is "as stripped" as the silver one above at the moment, :cry: but i couldn't bare to take a pic of her like that,so don't have a pic to refer to.
maxheadroom
Post by maxheadroom » Mon Feb 09, 2009 9:46 pm
bigdaddycain wrote:My bongo is "as stripped" as the silver one above at the moment, :cry:
Y
Keep the Faith
Post by bigdaddycain » Mon Feb 09, 2009 9:51 pm
Y
Sorry to off topic, nothing scary max, i decided (at last) to address the slightly scabby front slam panel,so it's stripped for new paint. :wink:
maxheadroom
Post by maxheadroom » Mon Feb 09, 2009 9:54 pm
cool 8) just in time for Snowdonia :D
Keep the Faith
paramatt
Post by paramatt » Mon Feb 09, 2009 11:17 pm
Two on this 2000 model bongo....
It may have two- but I still don't think it will pass its MOT!!! :D
Listen to the beat of the Bongos!! Black V6 tin top
Post by bigdaddycain » Tue Feb 10, 2009 7:39 pm
:lol: No... There is a small crack in the windscreen directly in the driver's eyeline.... The rest might t-cut out... :shock:
Trouble at t'Mill
Post by Trouble at t'Mill » Tue Feb 10, 2009 7:44 pm
Big Daddy, what's the larger 'horn-like' item just below the actual horn on the driver's side in that pic?
scanner
Post by scanner » Tue Feb 10, 2009 7:48 pm
A (bigger) horn.
Post by bigdaddycain » Tue Feb 10, 2009 7:52 pm
Trouble at t'Mill wrote:Big Daddy, what's the larger 'horn-like' item just below the actual horn on the driver's side in that pic?
Erm.. yes, a bigger horn it would appear. :shock:
stansyerman
Post by stansyerman » Tue Feb 10, 2009 10:03 pm
mot failed on horn not working ](*,)
dandywarhol
Post by dandywarhol » Tue Feb 10, 2009 10:19 pm
You can access the horn from under the bumper - don't need to remove the headlamp - just a 10mm head setscrew and 1 wire.
Post by teenmal » Wed Feb 11, 2009 12:30 pm
stansyerman wrote:mot failed on horn not working ](*,)
I wonder why :? :?
Hi Stan,the horn/horns are part of the MOT.
Cheers Mal..
Post by teenmal » Wed Feb 11, 2009 1:22 pm
I wonder why :? :?
Cheers Mal..
Was it only the horn that it failed on ??
stansyerman
Post by stansyerman » Wed Feb 11, 2009 10:50 pm
yes horn works but have a brake in the wire going to the horn
teenmal wrote:
I wonder why :? :?
Cheers Mal..
