sounds like a plan has just come together
good point, i forget its not always obvious to everyone to slowly release the cap off the expansion tank.westonwarrior wrote:Warning
If you go down the route of warming up the engine before doing this be very careful when taking off the filler cap
easily done in ten to fifteen mins for the method i described,spout wrote:Are you sure all these alternative methods for getting the anti freeze in are not more hassle than just draining out, refilling properly and rebleeding?
Agree, Haydn swings and roundabouts, pros and cons for both methods, i suppose it depends on how confident you are to drain and bleed the system.haydn callow wrote:Think you have a good point there "sprout" see my first reply !!
DBO... Iv'e never had to rebleed or top up after a refill/bleed. At least you will know it's all in there and properly mixed...swings/roundabouts I suppose....each to his own....!!
Now, how about extending this debate. If we are gong to do that, then is there any reason why you couldn't do an effective coolant change using the same method? I'm getting tempted.bigdaddycain wrote:The method we employed as used on KK's bongo ENSURES that an airlock is avoided in the first place, as it follows the principles of "the hosepipe method".
Other way round you mean Ste? Exiting water is being replaced by the neat coolantbigdaddycain wrote:The method we employed as used on KK's bongo ENSURES that an airlock is avoided in the first place, as it follows the principles of "the hosepipe method".
For the uninitiated, the H/P method reduces the chances of airlocks by purging the air as the coolant is added in the first place.
This is the safest way to strengthen the coolant in my opinion, as neat antifreeze is being replaced by the exiting water simultaneously.
Nah mean?
DOH!... Yep...missfixit70 wrote:Other way round you mean Ste? Exiting water is being replaced by the neat coolantbigdaddycain wrote:The method we employed as used on KK's bongo ENSURES that an airlock is avoided in the first place, as it follows the principles of "the hosepipe method".
Nah mean?
No thanks luv... i've just had one!missfixit70 wrote:Long night?
