Small lever under bonnet.
waycar8
Re: Small lever under bonnet.
Post by waycar8 » Wed Nov 12, 2008 7:41 pm
both my bongos ive owned have been from the north of japland, and both had climate control and both had that lever, but wasnt controlled by the unit in the cab
but my first 95 n had the same intake as the picture but my new 97 r has the same but with an extra vent running across the top so it can draw air in from the top of the vent intake cover as well as the front of the intake cover
Post by haydn callow » Wed Nov 12, 2008 7:50 pm
Part 61-805 on that diagram is the flap that was moving by moving a slider. It either was flush with the floor of the trunking in position 1..or...Position 2..it flapped upwards into the trunking (hinge at back) so it deflected air that would have gone along the trunking out and down.
I think !!
Post by haydn callow » Wed Nov 12, 2008 7:54 pm
Hang on ! more tosh !!!
In that diagram (lushprojects) the flap is hinged from the top of the trunking....The one I saw defo hinged up from the bottom !!
dandywarhol
Post by dandywarhol » Wed Nov 12, 2008 8:01 pm
I'm sure 61-B05 is worked by a control in the cabin - the winter/summer manual flap shuts off the incoming cold air from the extreme front of the engine bay and draws it from the warmer direction at the baulkhead
waycar8
Post by waycar8 » Wed Nov 12, 2008 8:06 pm
not sure what you mean? are you talking about the intake (61-820) or the cowling that the fan motor is in? (61-B05)
waycar8
Post by waycar8 » Wed Nov 12, 2008 8:08 pm
beat me DW :lol:
maxheadroom
Post by maxheadroom » Wed Nov 12, 2008 8:08 pm
just pull it :shock: :lol: :lol:
Keep the Faith
Post by haydn callow » Wed Nov 12, 2008 8:14 pm
Have had a good look at lush projects...Is there not two totally different versions of the whole intake cowling ??
Yep...just pull it.
Post by haydn callow » Wed Nov 12, 2008 8:17 pm
I'm off to annoy another Topic...Dandy...was your NW remark a innocent oversight ?? You'll get a telling off !
waycar8
Post by waycar8 » Wed Nov 12, 2008 8:28 pm
haydn callow wrote:Have had a good look at lush projects...Is there not two totally different versions of the whole intake cowling
Ive said that already :-s :lol: , either way the question was what the pictures are? it just controlls a flap inside the intake cowling from either direct flow of air through the front of the car or if the lever is the other way it will let air come up through the bottom of the intake cowling from the floor up.
dandywarhol
Post by dandywarhol » Wed Nov 12, 2008 11:16 pm
haydn callow wrote:I'm off to annoy another Topic...Dandy...was your NW remark a innocent oversight ?? You'll get a telling off !
:roll:
mister munkey
Post by mister munkey » Wed Nov 12, 2008 11:40 pm
My winter pack has the lever. Its in the manual as being an adjuster for cold weather motoring but the diagram is somewhat ambiguous as to which way it should be flicked for cold.
:-k
manners
Post by manners » Wed Nov 12, 2008 11:46 pm
Back for cold forward for normal climate.
emma & ian
Post by emma & ian » Thu Nov 13, 2008 7:40 am
I'll move it to the back and see if it makes any difference, thanks for your help.
thedogsbollox
Post by thedogsbollox » Thu Nov 13, 2008 8:28 am
If you take the advice of just pulling it, please retire to a safe distance.... :lol:
