Got it- definitely now! At this rate I'll be an expert of the none manual- instructer sort
Thanks a lot ,Anna
rwill19050 wrote:Me again.
Well, it was a seized fan that caused the problem.
Stripped it to it's component parts and found that the bottom fan bearing was swimming in a rusty sludge.
Also one of the brush springs was jammed in (they are steel, one rusted solid)
So, stripped the motor down, cleaned all the rust and cr*p from the bottom bearing housing and drilled a small hole to allow any future water to escape.
Freed the sintered metal bearing from the shaft, soaked it in WD40 then engine oil.
Re-lubed it all and re-assembled it (having use the magic WD40 to free the rusted spring).
Checked the resistor pack, sure enough, the connection taking the live feed to the resistors has melted it's connection.
Re-soldered it, put it all back together and now have a fully functioning fan system again.
Fitted new glow plugs, as staring became a problem (two burned out but replaced all 4).
Also had an intermittent fault with the window switch not working when the door was open.
Stripped the loom from the body to the door and found 1 broken wire, 4 wires at the point of breaking.
The plastic covering on the wires has gone brittle, so I had to bridge the faulty ones with wire links soldered in.
I'll remake the door loom when the weather gets warmer.
Brownie points to me today, back to painting the doors in the house tomorrow
I have earned my bottle of wine on Friday evening
Sure does.mikeonb4c wrote:Wow - a really impressive and useful days work there rwill19050![]()
Makes you feel real good don't it
Forget the reactor and celebrate with a case of cold beer. The emissions will be a lot less dangerousrwill19050 wrote:Sure does.mikeonb4c wrote:Wow - a really impressive and useful days work there rwill19050![]()
Now, if I can just get this second hand nuclear power plant that I salvaged from a Russian submarine working I will be ready for winter.
What was that bang?
Thank you so much Kirstymissfixit70 wrote:Nice one Anna - top result, now get soldering that old resistor up as a spare
A good point about the Bongo is even without a heater fan, the engine lump between the seats warms up on a decent run and provides heat. But of course that won't help the windscreen demist, so of limited use as you have to drive with the windows open and pray !!!not so old wrote:Hi Mike,
Thanks- Yes all done and now have heater![]()
Such luxury when you have been without for a few days Eh?
It was the misting that was causing the main hassle.
I think we too will try this Anti rain stuff. Sounds good!
Cheers Anna
brorabongo wrote:My number 3 setting is'nt working at all, settings 1, 2, and 4 are ok, does this sounds like a resistor fault?
