"FLOPPY" Wing Mirror
lizard
Re: "FLOPPY" Wing Mirror
Post by lizard » Sun Oct 26, 2008 8:18 pm
Is the shaft on the motor the correct size to fit the existing worm gear? That may help come to a decision. :|
F Zappa
Post by haydn callow » Sun Oct 26, 2008 8:29 pm
Yep !! 2mm
lizard
Post by lizard » Sun Oct 26, 2008 8:37 pm
Well, I supose if you can fit/wedge/glue/locktite/gluegun the motor in tightly.......sorry I can't be more help, then it should work [-o< ,if the motor has enough grunt to move the gears.
F Zappa
Post by missfixit70 » Sun Oct 26, 2008 8:47 pm
I'd meant to source a new motor as mine is very temperamental (even when connected to 12v direct on the bench before the door wire loom suggestions start :wink: ) I'd be interested find a reasonable priced effective replacement, even got as far as noting all the dimensions (now lost #-o ).
Sounds like this one could be a goer, wasn't expecting it to be that much, is it worth trying model shop type suppliers, if there is such a thing outside of what's been suggested already?
Keep us posted Haydn, sorry I couldn't be more help at this stage :wink:
Post by haydn callow » Sun Oct 26, 2008 8:48 pm
thats what I think and the mounting holes can be ajusted on the plastic mounting bracket. It should have loads of power. There are a couple of mirrors going on ebay so I may get one of them and still get a motor to see if it can be done. Would be a good thing to know for the future. Once you know how the removal and stripping down is not so hard...Thanks for all the replys with photo links...just the ticket...Bloody good forum this. Lets keep it that way !!
Post by haydn callow » Sun Oct 26, 2008 8:53 pm
Kirsty...don't think a model shop cheap motor would be up to the job. You get what you paid for ..the factory motor is a good heavy one so £20 is o.k. Mind you when you add VAT an p&p it comes to £31.
I think I will give it a go and put the price of the next 20 ****** up by £1.50. (tongue in cheek).
Will let you know
Post by g8dhe » Sun Oct 26, 2008 9:40 pm
mister munkey wrote:Is that not 6v Geoff?
Does that matter or not? 'Lectrics are a foriegn tongue to me!
Yes it does matter, but I gave the wrong link :oops: it was all part of the same data sheet which does include 12v versions as well, also 18v ones that could quite happily be underrun with no problems. The data sheet has more details on the entire range. Also Maxon have there own online shop it would seem https://shop.maxonmotor.com/ishop/app the A-max 22 110122 is the 12volt version at 29.93 Euro.
Post by haydn callow » Sun Nov 02, 2008 8:52 pm
All fixed and working ..£40 for a mirror off e bay. It would have cost £30 to try and fit a motor that may not have been suitable.
Post by missfixit70 » Sun Nov 02, 2008 8:54 pm
Glad you got sorted & you've got spare bits on standby too with the old one :wink:
Post by haydn callow » Sun Nov 02, 2008 9:42 pm
What you after Kirsty ???? thought you had the same folding problem.
Post by missfixit70 » Sun Nov 02, 2008 9:47 pm
I not after nuffink mister :wink: Mine's just temperamental rather than floppy, doesn't seem to like the cold & damp :-" [-X :lol:
Post by francophile1947 » Sun Nov 02, 2008 9:50 pm
missfixit70 wrote:I not after nuffink mister :wink: Mine's just temperamental rather than floppy, doesn't seem to like the cold & damp :-" [-X :lol:
OK, in view of your emoticons, I won't answer that :lol: :lol: :lol: :lol: :lol:
