Hi everyone,
Thanks for all you comments... Im still pulling my hair out on this one!
The fuse i am talking about is the large 100A blue one in the small fuse unit bolted to the main battery.
I just cant understand why the voltage regulator isnt doing its job?? Two alternators cant both have the same fault surely?!
I have an autoelectrician having a look on Saturday. This is getting a bit silly now. No car for 2 weeks and BIG BILLS soon to start coming in.
I have to admit that even i am finding it hard to stay 'Bongo positive' at the moment.
If it is a short i have no idea where it could be!? Must be a major one though and nothing seems obvious.
My worry is that the ECU may be involved in some way.....BIG BUCKS!!
Im sorry to hear that i am not the only one having problems at the moment... No such thing as highjakcing a thread.... We are all here to help each other!!
Thanks again everyone. I promise to keep you all updated to keep your thinking caps on and look back soon!
A sad, drained, confused and skint Lloydy.
HELP! - Electrickery problems!!
Re: HELP! - Electrickery problems!!
PROBLEM SOLVED TODAY!!
To cut a LONG story short the problem was traced to the actual fuse unit off the main battery. It was shorting out as was evidenced by a voltage difference between the battery and the alternator wiring. When the fuse unit was bypassed all was well!
I was told that due to the voltage drop in the fuse unit the alternator was working hard to chuck out enough to charge what it thought was a dead battery. Thing is the battery wasnt actually low and so the current had nowhere to go....hence the fuse taking the strain!
I dont fully understand all this but the guys working on it did and ELMO IS BACK ON THE ROAD!
Thanks for all you thoughts. I hope this helps someone else in the future and prevents them going through all that i did!!
Lloydy
Lloydy
Great news
- mister munkey
Well done for sticking with it matey & hearty congratulations!!!
Thanks guys
