Page 2 of 2
Re: Charging The Battery?
Posted: Sat Oct 18, 2008 7:54 am
by shaun.m
hi folks the compensator is CSI Airflow its Swiss made and the model no 5016-01 it is for indoor use only but wd keep the unit in the garage and trail wires out to the car on the 12v side, i can only say the do work and are brilliant all you do is plug in and walk away, the conditioner does the rest.
Posted: Sat Oct 18, 2008 8:22 am
by bigdaddycain
It sounds similar to this shaun.... (none of the type you mention on e-bay)
http://cgi.ebay.co.uk/CTEK-XS3600-Batte ... 286.c0.m14
Have a read up of the blurb, it sounds pretty good.... :wink:
A bit pricey in my opinion, but if it keeps the battery healthy (including the l/b) for an extra few years,then it will pay for itself in time.
Posted: Sat Oct 18, 2008 11:10 am
by shaun.m
this is a link to the conditioner we use hope it helps, as we use these at work i know they are good.
http://www.airflow-uk.com/shop_accessor ... ioner.html
Posted: Sat Oct 18, 2008 11:32 am
by bigdaddycain
Yep, looks good shaun,a bit cheaper than the e-bay one i found too,but it may strain the device a little if i try to charge my leisure battery with it, as my l/b is a 110 amp version. Still, a nice little item that i will consider for purchase... :wink: Thanks for the head up on it. :D
Posted: Sat Oct 18, 2008 12:25 pm
by francophile1947
Shouldn't be a problem Ste, especially as your LB is unlikely to be totally flat.
At the recent Essex Mini-meet, my little unit failed to cope with Hippotastic's totally flattened twin batteries, but all that happened was that it shut down (probably some sort of thermal cut-off :? ) - it worked fine again after a few minutes :D
Posted: Sat Oct 18, 2008 12:54 pm
Wouldn't it be nice if it could keep both the starter and LB batteries topped up at the same time. But I guess parallel connecting a 95Ah starter battery and a 110Ah LB and the nleaving hte conditioner to look after the lot is both a flawed idea and beyond the device's capabilities (or is it, as long as your batteries are not in a seriously flattened state?)
Price seems pretty good for this kind of stuff. I'd love to have a permanent installation so you could just plug a mains supply into the vehicle (on hookup or at home) and be confident that both starter and LB were being kept tip-top for the next outing.
Posted: Sat Oct 18, 2008 1:28 pm
by helen&tony
Hi Mike
You read my mind!! You probably remember , years ago, the unit you could wire up and fit under the bonnet, and it came with a waterproof socket, so you stop the car, plug into the mains, and leave it to charge the battery. It used to look like an ignition coil, and just fixed adjacent to the battery. I wonder if such a thing is still available? You also used to be able to buy mains water pre-heaters to keep the car's coolant warm in the winter, so you just jump in flick the starter, and the heater is all ready to go....ah, those good old days :D :D :D
Posted: Sat Oct 18, 2008 2:04 pm
by M 80NGD
shaun.m wrote:hi folks the compensator is CSI Airflow its Swiss made and the model no 5016-01 it is for indoor use only but wd keep the unit in the garage and trail wires out to the car on the 12v side, i can only say the do work and are brilliant all you do is plug in and walk away, the conditioner does the rest.
Thanks for the info Shaun,much appreciated. This will help the battery get through winter :D :D
Hope everybodys having a great weekend. Thanks for all the helpful advice,its all very welcome,cheers :D :D =D>
Posted: Sat Oct 18, 2008 3:55 pm
by David Edwards
Ah don't know if it will help but have a look at my entry in the thread above this one, lol.
Posted: Sat Oct 18, 2008 3:59 pm
by M 80NGD
David Edwards wrote:Ah don't know if it will help but have a look at my entry in the thread above this one, lol.
Hi Dave,I've just this minute tried to take a look,but it kept saying page not available :? I'll google it later,sounds like
another good option =D> :D :D Cheers,Lee.
Posted: Sat Oct 18, 2008 4:18 pm
by dp bradford
helen&tony wrote:.....You also used to be able to buy mains water pre-heaters to keep the car's coolant warm in the winter, so you just jump in flick the starter, and the heater is all ready to go....ah, those good old days :D :D :D
You can still get them :D Take a look here
Dave 8)
Posted: Sat Oct 18, 2008 4:34 pm
by helen&tony
Hi Dave
I saw one on e-bay (water heater)....off a Land Rover, and that was a Kenlowe....might look at this next year.
