Re: Is there an engine restricter?
Posted: Wed Oct 08, 2008 11:04 pm
That long?
A forum for Bongo fans and owners
https://igmaynard.co.uk/bongo/forum/
That is an engine RPM governor - what they are talking about here is an electronic road speed restrictor.ex25er wrote:All diesels have to be restricted, either mechanically or electronically, to stop them revving into infinity and.... whatever comes after that.
The best way is to sorce a local specialist and get the Bus remaped or Chipedbonglo wrote:Hi, Is the engine restricted on the Bongo. If so does it affect MPG etc.. I am not looking to go fast but i have seen ebay items talking about increased efficiency from removing restrictors. any thoughts.
p.s getting my Bongo on Friday !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!![]()
2.5D SGL5 - AFT - Aqua
To remap or chip an engine you need to have a chip in the first place and most Bongos don't have one, they are mechanically injected.wai.lee65 wrote:The best way is to sorce a local specialist and get the Bus remaped or Chipedbonglo wrote:Hi, Is the engine restricted on the Bongo. If so does it affect MPG etc.. I am not looking to go fast but i have seen ebay items talking about increased efficiency from removing restrictors. any thoughts.
they will give you the best advice
I had a Range Rover DSE done and it get loads more power and the MPG went up
by about 4mpg
I asl now of a few people who have had camper vans done with the same result
its about £250/300
Hope this helps...Lee
as i said sorce a local specialist, for best advice , Bongos have a ECUscanner wrote:To remap or chip an engine you need to have a chip in the first place and most Bongos don't have one, they are mechanically injected.wai.lee65 wrote:The best way is to sorce a local specialist and get the Bus remaped or Chipedbonglo wrote:Hi, Is the engine restricted on the Bongo. If so does it affect MPG etc.. I am not looking to go fast but i have seen ebay items talking about increased efficiency from removing restrictors. any thoughts.
by about 4mpg
its about £250/300
Nope, apparently the question has been asked many times and every time the computer says no.wai.lee65 wrote: as i said sorce a local specialist, for best advice , Bongos have a ECU
so surley it can be remaped?? or fuel pumps upgraded?
ive even know of old LANDROVERS modified as i use't to be heavly
involved with Landrover clubs and stuff
Lee
They have an ECU, but not one that controls the injection pump. I would guess the fly-by-wire ones must be electronically controlled and should therefore be chippable.bigdaddycain wrote:I dunno about the later "fly by wire" type bongo's (2000 onwards?), but most don't have an E.C.U. to chip, you can i believe have a mechanical tune,i.e. timing adjusted,fuel pump adjusted etc.
<from http://www.paramount-performance.com/ac ... uning.html>
# Ford
Significant Ford ECU remapping performance power increases available, prices start from just £250. Many of the Ford range of vehicles can be covered, including Fiesta, Focus, ST220, as well as Ranger and Transit performance tuning.
