Is there an engine restricter?
Re: Is there an engine restricter?
That long?
All diesels have to be restricted, either mechanically or electronically, to stop them revving into infinity and.... whatever comes after that.
Anything with an ecu can be chipped, anything with a mechanical pump... well you're pretty much stuck with it!
You could always play with the timing if you're desperate for more power (or efficiency). I might be wrong, but I think that's what black cab drivers do to make their cabs go a bit quicker. They might spew out a bit of black smoke along the way, and do a few less mpg, but if they can get more fares of an evening.....
102 with 8 up!! Blimey. There's 7 people who won't be blagging a lift off you again!!
Phil
Phil
That is an engine RPM governor - what they are talking about here is an electronic road speed restrictor.ex25er wrote:All diesels have to be restricted, either mechanically or electronically, to stop them revving into infinity and.... whatever comes after that.
The best way is to sorce a local specialist and get the Bus remaped or Chipedbonglo wrote:Hi, Is the engine restricted on the Bongo. If so does it affect MPG etc.. I am not looking to go fast but i have seen ebay items talking about increased efficiency from removing restrictors. any thoughts.
p.s getting my Bongo on Friday !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!![]()
2.5D SGL5 - AFT - Aqua
they will give you the best advice
I had a Range Rover DSE done and it get loads more power and the MPG went up
by about 4mpg
I asl now of a few people who have had camper vans done with the same result
its about £250/300
Hope this helps...Lee
To remap or chip an engine you need to have a chip in the first place and most Bongos don't have one, they are mechanically injected.wai.lee65 wrote:The best way is to sorce a local specialist and get the Bus remaped or Chipedbonglo wrote:Hi, Is the engine restricted on the Bongo. If so does it affect MPG etc.. I am not looking to go fast but i have seen ebay items talking about increased efficiency from removing restrictors. any thoughts.
by about 4mpg
its about £250/300
as i said sorce a local specialist, for best advice , Bongos have a ECUscanner wrote:To remap or chip an engine you need to have a chip in the first place and most Bongos don't have one, they are mechanically injected.wai.lee65 wrote:The best way is to sorce a local specialist and get the Bus remaped or Chipedbonglo wrote:Hi, Is the engine restricted on the Bongo. If so does it affect MPG etc.. I am not looking to go fast but i have seen ebay items talking about increased efficiency from removing restrictors. any thoughts.
by about 4mpg
its about £250/300
so surley it can be remaped?? or fuel pumps upgraded?
ive even know of old LANDROVERS modified as i use't to be heavly
involved with Landrover clubs and stuff
Lee
Nope, apparently the question has been asked many times and every time the computer says no.wai.lee65 wrote: as i said sorce a local specialist, for best advice , Bongos have a ECU
Lee
It may have an ECU but that doesn't control the injection.
Read--- http://www.igmaynard.co.uk/bongo/forum/ ... t=+chipped
But if you can find somebody who can do it you'll make a lot of owners very happy.
I dunno about the later "fly by wire" type bongo's (2000 onwards?), but most don't have an E.C.U. to chip, you can i believe have a mechanical tune,i.e. timing adjusted,fuel pump adjusted etc.
They have an ECU, but not one that controls the injection pump. I would guess the fly-by-wire ones must be electronically controlled and should therefore be chippable.bigdaddycain wrote:I dunno about the later "fly by wire" type bongo's (2000 onwards?), but most don't have an E.C.U. to chip, you can i believe have a mechanical tune,i.e. timing adjusted,fuel pump adjusted etc.
<from http://www.paramount-performance.com/ac ... uning.html>
# Ford
Significant Ford ECU remapping performance power increases available, prices start from just £250. Many of the Ford range of vehicles can be covered, including Fiesta, Focus, ST220, as well as Ranger and Transit performance tuning.
