If you have a TM-2 gauge fitted PLEASE read this
lev8
Re: If you have a TM-2 gauge fitted PLEASE read this
Post by lev8 » Thu Sep 25, 2008 10:17 am
Any news yet Haydn? It's getting warmer down under and my TM2 alarm is going off (101 C) when I restart after a short stop. I've noticed the temp can climb 8 degrees after a stop. The bongo temp gauge is, as usual, steady at 11
Can you recommend a safe alarm limit, my sensor is on the middle rocker cover bolt drivers side, currently running at 94-96 around town.
Post by haydn callow » Thu Sep 25, 2008 10:29 am
Sounds pretty good to me..The temp will rise a lot when you stop. As long as it stops as soon as you get going again I wouldn't worry. You could set it to 105.
