Page 2 of 2
Re: Turbo 'whoosh'
Posted: Fri Jun 20, 2008 9:04 pm
by lizard
Well I can't hear any sort of hissing, whooshing, rushing, whizzing, only an engine reving. Hope that's how it should be. :)
Re: Turbo 'whoosh'
Posted: Fri Jun 20, 2008 9:55 pm
by trevd01
lizard wrote:Well I can't hear any sort of hissing, whooshing, rushing, whizzing, only an engine reving. Hope that's how it should be. :)
Ditto
Re: Turbo 'whoosh'
Posted: Sat Jun 21, 2008 11:29 am
by bigdaddycain
nfn wrote:Some bongo turbos seem to be whooshier or hissier than others: it's quite noticable on mine if there isn't too much wind noise
Yep, that's quite true, the whooshing sound does ideed vary from bongo, to bongo. (in my limited experience at least) The whooshing increased in volume when i fitted a K&N, no bad thing, i like the sound of it. (i think it sounds sporty :lol: )
Re: Turbo 'whoosh'
Posted: Sat Jun 21, 2008 8:29 pm
by last_tuesday
Well I just put a K&N in mine and .................. it still doesn't whistle, pop, whine, scream... nor anything else, thankfully.
No audible turbo whistle, blow off valve shennigans, or anything else. Sounds just like a good engine should, quiet. Apart from the rather uncultured bangings and clatterings that a Bongo engine normally makes 8)
My car has a much more noticable turbo whistle, and blow off valve 'pssssst' sound. Even so, they are only really obvious when the window is down. Perhaps Saabs engines are noisy too, they just have very good sound proofing :)
Re: Turbo 'whoosh'
Posted: Sat Jun 21, 2008 9:37 pm
by lizard
My old landy disco used to whistle lovely when accelerating. If you can call it accelerating in a 2.5 TDI :lol: :lol: :lol: :lol:
The Bongo is like a sports car compared to that. :lol: :lol: :lol: :lol: :lol:
Re: Turbo 'whoosh'
Posted: Mon Jun 23, 2008 9:55 pm
by missfixit70
I can hear my turbo kicking in very faintly, but i have noticed that over time the seat/engine access retaining catches stretch out over time, I bent mine in a bit to tighten them & it was much quieter :D Maybe it's not so much differing amounts of noise from turbos, but differing amounts of noise getting through?
Re: Turbo 'whoosh'
Posted: Mon Jun 23, 2008 10:02 pm
by bigdaddycain
Yeah, could well be... I'll try the tweak with the catches too. :wink: I may try a spot of meguires rubber treatment on the seal whilst i'm at it, it seemed to work on the door seal on my car for a few months at least... :wink:
Re: Turbo 'whoosh'
Posted: Tue Jun 24, 2008 9:52 am
by Ralph
I was told by a turbo man that turbo whistle or whine what
ever you want to call it is due to very slight imbalance of
the turbo blades, it's nothing to worry about and in fact
some people ask for them to build it in when they recon
the turbo as they like the noise.
Re: Turbo 'whoosh'
Posted: Tue Jun 24, 2008 12:10 pm
by missfixit70
My dad's last camper, can't remember what it was based on, but it was only a couple of years old & the turbo sounded like a police siren in the distance - best speed monitor ever, you'd instantly check your speedo :lol:
Re: Turbo 'whoosh'
Posted: Tue Jun 24, 2008 2:50 pm
by haydn callow
Are you sure the noise is in fact coming from the turbo and not No 1 manifold stud ???
Re: Turbo 'whoosh'
Posted: Tue Jun 24, 2008 4:32 pm
by vanvliet
I have passed on the suggestions about what might be causing this noise ( including ref to the stud) She has in turn raised this with the seller who has agreed to look at it when it is being serviced / cambelt change so we will have to wait and see - - -
Re: Turbo 'whoosh'
Posted: Tue Jun 24, 2008 11:09 pm
You've all got me unsettled now. Mine has a lovely whistle but it always has had, and I like it. But have I been driving round for nearly 2 years with a broken stud?
Re: Turbo 'whoosh'
Posted: Wed Jun 25, 2008 10:41 am
by bigdaddycain
You'd definitely notice the difference in sound mike,if it was a broken stud, the noise would have got progressively worse as time went on. Plus, i suspect the sound would diminish as the engine warmed from cold.
I've heard your engine mike, there are no untoward sounds coming from it... :wink:
Re: Turbo 'whoosh'
Posted: Wed Jun 25, 2008 12:16 pm
by helen&tony
You may not have heard of the 11th Commandment....I think Moses may have dropped the Tablet....it states:-
All thy motors should be SUPERCHARGED
http://www.youtube.com/watch?v=8mrMpW2t ... re=related
Just listen, wait for it and let the sound chill thy bones
Re: Turbo 'whoosh'
Posted: Wed Jun 25, 2008 1:34 pm
bigdaddycain wrote:You'd definitely notice the difference in sound mike,if it was a broken stud, the noise would have got progressively worse as time went on. Plus, i suspect the sound would diminish as the engine warmed from cold.
Thanks Ste. I'll grab my teddy and go to bed now and sleep well :lol:
