cooling system overhall
Re: cooling system overhall
Thanks BDC. How much antifreeze need to be added to get a 40/60 ratio?
- maxheadroom
I beleive the total coolant capacity to be around 12-13 litres harpo, so i reckon that 5 litres of undiluted coolant should do the trick.harpo42 wrote:Thanks BDC. How much antifreeze need to be added to get a 40/60 ratio?
Some on here take the manufacturer's recommendation's a little TOO literally,bear in mind that a fair chunk of the warning stickers just don't apply here.
Ok thanks for all the help.
Off out now to sunbath and sip some rum in the oh so tropical atmoshpere.
Good luck...Sip one for me!
- Peg leg Pete
Well I have just done a coolant change, used 5 litres of coolant, as I did last time, The last coolant did have a noticable amount of rust colour in it when giving the radiator a good flush. I would not want to dilute the coolant any more than I have done -due to the rust inhibiting effect of the coolant being less effective
