I got my battery tray & split charge wiring loom from Willinton a couple of weeks ago, fitted it tonight, took all of an hour to fit the lot, 10 minutes of that was spent finding the right size tap to clean out one of the threaded holes on the bongo. Seems to work fine, fantastically well put together & so easy to fit, you could almost do it blindfolded - not recommended though
. Nearly put my back out putting the 110amp battery in, especially when I realised I had to take it out again to fit the earth lead
. Big thankyou to Martin, fantastic bit of kit
Would recommend it to anyone & have go at fitting it yourself, so go for it kitegirl
