Bounce on the lefthand side front and rear to check that the dampers are working ok. If you can't find a problem there check the left rear suspension. Hope this helps.davetingle wrote:Yes it does seem to handle differnetly when turning left and right, The left turn is not too bad, it is the right turn which is the problem with understeer which throws me out to the left .....
