Page 2 of 2
Re: Losing water .......OMG Its Hot
Posted: Sat Apr 26, 2008 9:47 am
by oldgit
You'll need to replace the split hose and then bleed the system following the Bongo procedure
. The other symptoms are normal, the bottom hose only gets warm after the thermostat opens.
Posted: Sat Apr 26, 2008 10:44 am
by chrisd2211
oldgit wrote:You'll need to replace the split hose and then bleed the system following the Bongo procedure
great Thanks where do i find "Bongo Procedure"
Thanks Chrisd2211
Posted: Sat Apr 26, 2008 2:05 pm
by oldgit
If you do a search on the forum, you should find it. It's a bit complicated to write it down, but if you can't find it, I'll do my best to write it for you.
Posted: Sat Apr 26, 2008 4:06 pm
by francophile1947
Thanks Chrisd2211
Fact Sheet in Member's area. :D
Posted: Sun Apr 27, 2008 9:04 pm
by chrisd2211
Guys & Gals a big thanks to all of you that have helped and made suggestions toward curing my problem, it is I'm glad to say well I least I think it is Fixed!! it was a split hose over the starter motor and fortunatly no long term damage appears to have been done!! I must say A Really BIG!!!!!! Thankyou to The Great Pretender who spent time on the phone to me trying to talk me through the BLEEDIN process ( I mean Water System Bleedin!!) his expert help was invaluable and of great service. So thanks again no doubt Ill be back soon!!
Regards Chrisd2211
