sender unit
susan
Re: sender unit
Post by susan » Mon Apr 14, 2008 7:16 am
Had a look and i have a black sleeve over mine,seems to be connected but will comment to the garage,if it has blown what am i looking to buy :?:
dandywarhol
Re: sender unit
Post by dandywarhol » Mon Apr 14, 2008 9:33 am
The Great Pretender wrote:
dandywarhol wrote:I set mine midway at 3mm but there's so much yield on the suspension rubber bushes and sidewalls on these Bongos I doubt 6mm would make much difference than 3mm.
At the speed we drive at around town I dont think 'yield' is a problem. Sidewalls of the tyres are different and normally the taller the sidewall the greater the slip angle.
I'm not going to get into an arguement/discussion/debate about it Mel, especially as it's off topic.
As far as I know and concerned there's enough rubber bush flex, positive camber/sidewall flex on these machines to pull the wheels parallel when moving and that's the only reason for road vehicles for having toe in/out.
The Ackerman principle doesn't have anything to do with the initial toe settings - its all about ensuring that all the wheels follow a true rolling path when cornering to avoid excessive tyre scrub.
Re: sender unit
Post by mikeonb4c » Mon Apr 14, 2008 1:27 pm
susan wrote:Had a look and i have a black sleeve over mine,seems to be connected but will comment to the garage,if it has blown what am i looking to buy :?:
Hi Susan.. If it has blown, suggest phone Bongobits to see if they can help and/or contact Ian as he has a complete parts finder service. Also, don't rule out trying local motor factors as some of them have the Bongo on their database and it may turn out to be a standard item. Finally, you could get one off a breaking bongo. OR, you could say - I'd rather have a true read out of engine temperature by getting a TM2 sensor and digital readout, and spend repair money instead on fitting that? Good luck
Mike 8)
The Great Pretender
Re: sender unit
Post by The Great Pretender » Mon Apr 14, 2008 9:31 pm
Slap my wrist. :lol: :lol: :lol:
To infinity and beyond
