broken bracket, leaking pipe, imminent mot.
Hose clips arrived from Manflex this morning, pretty quick as I only ordered them on Thursday morning, They are packed in pairs for each hose, Look very substantial & good quality, well done BDC for finding these guys & getting them on side. I'll try & post the sizes to relevant hoses later. Not looking too hopeful for a hose day tomorrow though
Back is well & truly stuffed
Managed to get the hoses done today, thanks to my friendly tyre fitter letting me use the ramps, took a very leisurely (creaky & painful) 4 hours from getting there to having everything packed up, including a good half hour flush & bleed ( the bongo - not me
) & checking everything at least 3 times, as well as changing the diff oil while I was at it.
All seems ok, by the state of some of the hoses coming off, I would recommend anyone to get this done asap, or do it yourself, it's not that scary as long as you take your time, thoroughly clean the connections with some wet & dry, make sure none of the pipes are likely to rub, if they are make sleeves from the old pipes or reuse sleeving that is on the old pipes.
It could easily be done on your driveway with ramps or axle stands. If I managed to do it with a b***ered back, anyone can do it
Hose clip sizes - 8 of 35-50mm for the 4 larger hoses,
4 of 17-25mm or 22-30mm on the expansion tank to rad & engine to rear heater ( under air intake) (another 4 of either of these sizes if you do the remaining 2 short hoses)
2 of 16mm on the bleed hose
- brorabongo
- brorabongo
sorry ta hear about your back kirstybrorabongo wrote:Missfixit70. You definitely picked an appropiate forum name for yourself. Hats off to you. ( if I where wearing one)
When do you fancy coming up North to do mine?
@ flippa hows the stock of hoses?
brora ......set wise im down to the last few sets.... black only
