Page 2 of 2
Posted: Wed Jan 16, 2008 12:13 am
by Cloughy
Thanks, I'll check the header tank/cap tomorrow and get the system checked at the garage ASAP.
Posted: Wed Jan 16, 2008 12:17 am
by haydn callow
Cloughy,
You should not be needing to top up on a regular basis. As already said. Check the cap on the header tank and also the cap on the radiator. Other than that look for mist/spray around all hoses/metal pipes with the engine hot and running. Check all hose clips for weeping.
Posted: Wed Jan 16, 2008 12:20 am
by Cloughy
Will do.
thanks
Posted: Wed Jan 16, 2008 12:57 am
by coco bongo
My apologies Ian! Just checking.
Posted: Wed Jan 16, 2008 2:09 am
by cheffy34
haydn callow wrote:Well that settles it. The Coolant alarm is o.k, for both the diesel and V6 and the instructions apply to both with no changes.
Phil at JAL gets his alarms from me and fits loads of them.
Now I know he has fitted them to the V6 all doubts are gone.
I've not heard of V6's having problems with the head gaskets/cylinder heads but the hoses are getting on a bit in many cases so the fitting of a coolant loss alarm can only make sense.
Shucks take it that means i dont get a free one for being a guinee pig Haydn, would have done it tho :cry: Well next time A :wink:
Posted: Wed Jan 16, 2008 11:21 am
by haydn callow
cheffy...have pm'd you
