What's going on here then? Exhaust gas in my face!
- brorabongo
If the cause of the fumes is determined, then consequently the monoxide issue should be theoretically rectified also...
As an afterthought, does the bongo have one of those flaps to stop the cabin pressurising? Could that be close to an exhaust leak?
But that doesn't explain the lack of fumes when the heater is switched to recirculate.... Hmm, its a tricky one is this...
I suspect a manifold leak.... But without the screech?
- dandywarhol
You're right to be concerned Trev but the carbon monoxide in diesel exhaust is minute compared to a petrol engine. That's one reason the Nazi's didn't use diesel trucks at Auschwitztrevd01 wrote:Why am I the only one worrying about carbon monoxide here
Trev is absolutely right to be concerned about CO poisoning. I had a contractor working for me a few years ago who had complained about headaches etc when driving his car. He failed to turn up for work one morning and we later got a call from the police. He had been overcome by fumes on the motorway and somehow managed to get over to the hard shoulder before collapsing over the wheel. It turns out he had a fuel leak which was dropping onto the hot exhaust and the fumes were getting into the cab. He recovered but it could have been very nasty. As Dandy says, diesel isn't as bad as the fumes from petrol but dangerous just the same. I suggest you find the cause and not simply put up with it.
Took the bongo to work this morning and in the traffic with the heater on I did get a chip smell.
I called in at the bongo garage and have booked the bongo in for friday.
However on the way home I parked outside a shop for 10 mins with the heater on and no smell.
I am beginning to wonder if it is just which way the wind is blowing.
I lifted the bonnet and had a good smell with the van running and couldn't smell anything yet sometimes I can smell chips just climbing out of the van.
Where exactly does the heater pick up from? Is it the scoop that sits just above the radiator?
Darren
Darren
- brorabongo
- brorabongo
