On my first Friendee i put all 235/60/16 and when steering, the wheel rubbing bumper. Had to cut the corner bumper (2 cm) near the wheels.
On my new car whith 235/50/17 this dont need.
Our Friendee owners set 225/75/15 and cut front bumper corner. This size like 235/60/17 (difference -0,7%) and 215/65/17 (dif-1%). More size do rubbing bumper when steering.
Once & For All - Tyre size advice please. . . .
Russian Mazda Friendee Club
http://www.mazdafriendee.ru
Just calculate it:
Without rubbing overal tire size < 680-685 mm (IMHO)
I am tested:
235/50/17=235*0.5+17*25.4+235*0.5=666.8mm not rubbing
225/60/16=225*0.5+16*25.4+225*0.5=676.4mm not rubbing
235/60/16=235*0.5+16*25.4+235*0.5=688.4mm rubbing
logical
215/65/17=215*0.65+17*25.4+215*0.65=711,3mm will rubbing
215/60/17=215*.6+17*25.4+215*0.6=689.8mm will rubbing, but need to test , because front suspension configuration may be different( more strong springs, new or old rubber bushing in lower arm...)
If litle lift suspension, then may put 255/60/17 like this
I am tested:
logical
mikeonb4c for 2WD you can put any size on rear axle, 235/60/17 or more. But on front axle you can not put tire more than 685 mm overal size (example 235/50/17) without cuting bumper.
How would it look? If different between front and rear tires will be more than 4-5 cm, it will be not good for view (IMHO).
I guess the way to test it is drive the rear wheels onto a 4-5cm ramp and then see how it looksDemonAV wrote:How would it look? If different between front and rear tires will be more than 4-5 cm, it will be not good for view (IMHO).
DemonAV - how much cutting of the front bumper was required and was it easy to make it look good?
Thanks again for writing on this thread - really interesting. Its amazing to be having conversations with someone in Russia like this. When I was young, that would have been impossible.
Mike
PS - In summary, I think that 215/55/17's on the front and 215/60/17 or even 215/65/17's on the back might be reasonable on a 2WD provided you don't mind the 'nose down' look (I saw Torchwoods at Silverdale and thought it looked quite good in a nose down attitude - whether a green/silver '95 model will look as good remains to be seen!).
Its easy. Cuting invisible part of bumper, part of attachment before the whee. Look picmikeonb4c wrote: how much cutting of the front bumper was required and was it easy to make it look good?
- dandywarhol
- The Great Pretender
- mister munkey
You guys really are Gods amongst Men.
- And Women, of course & also those of an unspecified genital group.
Many thanks.
Many thanks.
