Posted: Wed Dec 12, 2007 10:18 am
I bid £30.
Scanner.....I have my desgn team working on that possibility at the very moment...scanner wrote:Any chance of modding one to fit the gutters on a tintop?
Alan, if you are popping over on Sunday, bring your tape measure!alant54 wrote:Scanner.....I have my desgn team working on that possibility at the very moment...scanner wrote:Any chance of modding one to fit the gutters on a tintop?.......but I could do with a tintop to get the dimensions to see if it is feasible.....nothing is impossible in Bongland......Alan
No probs Alan. yes, structural integrity is a thing to watch out for esp. as I now know it is GRP not aluminium. It might be worth seeing if roof box mounting point distances are standardised. If so you could have alternative crossbar bolt through points for those standard distances. Also, probably only need one of the bars to be moveable although it would be ideal to have both front and rear ones adjustable.alant54 wrote:Mike ......what a great idea....I will explore that possibility without compromising the strength of the rack.mikeonb4c wrote:Provided you had the tooling to do it, it looks as though the design chould be modified so the cross bars were bolted through slots in the longitudinal runners. Loosening the bolts would allow bars to be slid for and aft a certain amount to fit topboxes, and then tightning the crossbar bolts would fix the bars in position. Just a thought
Mike I have been in conference with the grp boffins today and the slot is a no no......it would compromise the stength of the rack.....but drilling two extra 11mm holes and relocating one of the crossmembers would be ok...........Alanmikeonb4c wrote:No probs Alan. yes, structural integrity is a thing to watch out for esp. as I now know it is GRP not aluminium. It might be worth seeing if roof box mounting point distances are standardised. If so you could have alternative crossbar bolt through points for those standard distances. Also, probably only need one of the bars to be moveable although it would be ideal to have both front and rear ones adjustable.alant54 wrote:Mike ......what a great idea....I will explore that possibility without compromising the strength of the rack.mikeonb4c wrote:Provided you had the tooling to do it, it looks as though the design chould be modified so the cross bars were bolted through slots in the longitudinal runners. Loosening the bolts would allow bars to be slid for and aft a certain amount to fit topboxes, and then tightning the crossbar bolts would fix the bars in position. Just a thought
Great idea though. Crying out to be done so full marks for doing it!
According to my measurements the clearance needed above the gutterline is at least 150mm to clear the fluted profile of the roof. It could then be fitted behind the sunroof (if fitted) which would allow very easy access for loading and unloading.alant54 wrote:Scanner.....I have my desgn team working on that possibility at the very moment...scanner wrote:Any chance of modding one to fit the gutters on a tintop?.......but I could do with a tintop to get the dimensions to see if it is feasible.....nothing is impossible in Bongland......Alan
