gear select display on dash
scanner
Post by scanner » Sun Nov 25, 2007 6:39 pm
bigdaddycain wrote:The gear selection indicator in the dashboard seems to be late 97 onwards models. Along with low fuel warning light.
I'm a pauper with just a gear position display next to my shifter... :(
Mine is early 98 "R" reg and it has neither gear display nor, so far as I can tell, low fuel warning.
pippin
Post by pippin » Sun Nov 25, 2007 7:23 pm
One can tell if there isn't a low fuel warning light - usually by coasting to a halt unexpectedly!
Seriously, if a low-fuel warning indicator is fitted one can just about see it briefly in the dash display when the ignition is switched on and all the other warning lights come on. Best done at night without sidelights on.
MountainGoat
Post by MountainGoat » Sun Nov 25, 2007 7:35 pm
Perhaps it is a grade option. Mine has an automatic air conditioner. Does the none fuel warning light jobbie have a manual air conditioner?
pippin
Post by pippin » Sun Nov 25, 2007 7:36 pm
No connection between the two.
Bica
Post by Bica » Sun Nov 25, 2007 7:57 pm
My S Reg Freda has both (and the digital air con controls}
Nao faz mal
Brian
cheffy34
Post by cheffy34 » Mon Nov 26, 2007 2:04 am
mine also has digital air con, l know ive had cars before and when ive tried getting parts for them have often been told that the particular part i want is from a later model, usualy costing more money :roll: suppose they do it to turn over end of production stuff on other models
Post by bigdaddycain » Mon Nov 26, 2007 11:46 am
The digital aircon isn't age specific,although it was more popular in later models, and the extra,dashboard gear selector,and low fuel warning light started to appear at late 97 onwards... Generally speaking, if your bongo is new enough to have the passenger airbag,then its new enough to have the dash lights.
You know how it is with the spec of bongo's...there is no set rules,you get, what ya get.... :lol: :lol: :lol:
cheffy34
Post by cheffy34 » Mon Nov 26, 2007 12:02 pm
bigdaddycain wrote:The digital aircon isn't age specific,although it was more popular in later models, and the extra,dashboard gear selector,and low fuel warning light started to appear at late 97 onwards... Generally speaking, if your bongo is new enough to have the passenger airbag,then its new enough to have the dash lights.
dont suppose you know the answer to my original question on this thread bdc
Post by bigdaddycain » Mon Nov 26, 2007 12:08 pm
Sorry cheffy. Aaprt from the usual connection checks i can offer no practical advice mate...
Its not a big job removing the instrument cluster though bud, the steering wheel doesn't even have to be removed,just a few screws, and careful as ya go! :wink:
I'll bet you a new pair of socks, that the connection at the warning light end is either dirty,come loose, or badly earthed... :wink:
cheffy34
Post by cheffy34 » Mon Nov 26, 2007 12:16 pm
gives me an excuse to change to white dials while i got it apart i suppose :D
i reckon your prob right n itll be a wire clock end, thanks all the same what size foot are you incase and will used ones be ok cause im a tight ...... :)
Post by bigdaddycain » Tue Nov 27, 2007 11:14 am
:lol: :lol: Size 12's...and yes second hand will do nicely...i'll just turn em inside out :lol:
It does seem a shame to take the cluster to bits without discreetly slipping some white dials in whilst your at it.... :wink:
