Glow plugs
jimsmimm
Post by jimsmimm » Tue Nov 06, 2007 8:19 pm
dont forget that not all bongos use the same length plugs as some have a modified rail and therefore different plug lengths..... :-s
ford tinny
Twin coil ?
Post by ford tinny » Tue Nov 06, 2007 11:07 pm
Hello all, Iv'e just purchased Twin coil glow plugs. They say that these are far better than standard glow plugs. Has anybody fitted these and if so do they do what it says on the tin!
Thanks John (ford tinny) :wink:
scanner
Post by scanner » Wed Nov 07, 2007 12:13 am
jimsmimm wrote:dont forget that not all bongos use the same length plugs as some have a modified rail and therefore different plug lengths..... :-s
No where I've found lists any alternatives to the one above.
What rail is modified? The power supply or what? and how is it modified.
Post by bigdaddycain » Wed Nov 07, 2007 1:48 am
Yep ,the insulated connector in some cases can arc onto the engine,causing the fuse to repeatedly blow,spacing the rail with washers can offer more clearance. This scenario occurs when shorter plugs are fitted to bongo's that originally had the longer plugs.
Longer glowplugs were a temporary "fix" by mazda when 83mm plugs were hard to source,a series of bolts was incorporated by mazda to adjust the height of the glowplug rail.
AlanHunter
Post by AlanHunter » Wed Nov 07, 2007 9:16 am
Thanks Mick.
Are NGK Y701J plugs 83mm?
How long have these lasted in your Bongo?
mick
Post by mick » Wed Nov 07, 2007 10:04 am
AlanHunter wrote:Thanks Mick.
Hi Alan
They are 85mm - standard I think. Measurements can be seen by clicking on link
http://www.veletrh.com/koupit/y701j-zhavici-svicka-ngk
Lasted 2 years so far. Always used NGK for bikes and cars. I really don't expect to have problems with them.
AlanHunter
Post by AlanHunter » Wed Nov 07, 2007 10:16 am
Many thanks Mick.
I will get some in ready for next time.
fordavefreda
Post by fordavefreda » Wed Nov 21, 2007 10:23 pm
with the diferences in length of the glow plug ie; 103mm/ 83mm does the reach of the plug inside the cylinder head remain the same?
my freda is a 4wd sgl5 with 103mm plugs.
need to know if the 83mm ones fit without too much hassle?
MountainGoat
Post by MountainGoat » Wed Nov 21, 2007 10:56 pm
To find the length of the Glow Plugs that will fit your Bongo, you will first have to find out the Bongos vin Number which can be found on the drivers door. Then look up the fact sheet on Glow Plugs in the members section.
Post by bigdaddycain » Wed Nov 21, 2007 11:48 pm
fordavefreda wrote:with the diferences in length of the glow plug ie; 103mm/ 83mm does the reach of the plug inside the cylinder head remain the same?
Yip, the size of the plugs inside the cylinder head is the same, its longer "at the other end"....
