metallic marble type noise
smartmonkey
Post by smartmonkey » Mon Oct 15, 2007 1:19 pm
The injection pumps have an advance and retard sytem that times injection acording to engine load/revs. If this goes out of kilter it will cause a horrible noise but it sounds like an old truck engine - not marbles. One faulty injector can make a banging noise so it could be that, but I would expect to hear it at light load as well as heavy load. It might be worth checking engine mounts and exhaust/cooling pipes for knocking. Have a good check underneath for anything that might clang under load.
scanner
Post by scanner » Tue Oct 16, 2007 10:50 am
I've just had this reply to posting your question on another forum.
I have had a similar noise in a petrol Opel Manta auto and the torque convertor had come loose on the flywheel. managed to tighten it up one at a time through an inspection hole. Perfect after that.
That would sound very logical to me.
dandywarhol
Post by dandywarhol » Thu Oct 18, 2007 8:27 pm
I think you can get access to the T.C. bolts through the plate bolted to the gearbox which holds the exhaust bracket on.
