Compatible Parts Database
Just fitted a new sump plug, I found that a Ford part no.SP452 from the little shop down the road though a bit longer did the job perfectly well.
Well it did untill after filling her up with oil I found the plug washer in my pocket grrrrr!!, still debating whether to empty it all out or wait and see if it leaks.
Paulo
Paulo
- dandywarhol
Bulbs for dash switch illumination & climate control http://www.maplin.co.uk.
Coloured subminiature bulbs 3.2 mm dia - PG79L (green)
clear wire terminal type bulbs 3.17mm dia- BT43W. both of these are the same size as the window blind switches & will fit the climate control, but the clear bulbs are too small for the green "condom" from the climate control bulbs to stay on.
Clearwire bulb 5mm dia - WQ13P should be big enough to hold the green "condom", but I haven't tried them. <edit> I have tried them now, slightly too big to fit through the hole ( tore the condom
), could probably be opened out slightly?- I couldn't be bothered <edit>
The thin flexible wire legs are necessary to be able to refit them into the holders
12v coloured leds with integral resistors also available from them 3mm & 5mm, need a little bit of modification & soldering to fit as the legs are too thick & inflexible to fit directly back into the holders.
See this thread replacing bulbs & fitting led's
- Tribal Elder
Yup, front foglamp switch plugs straight in I know as i`ve got one fitted in my van - the rear foglamp switch fits with a little mod to the wiring and about 6 to 9 inches of the wiring coming out of the back of the switch - It`s just a case of knowing which wire does what but you will need an additional LED to show you when the rear lamp is lit to pass the MOT.
If I had all the money I ever spent on my Freda ............ I`d spend it on my Freda.
Starter motor assembly (including solenoid and contacts) for the Mazda V6 2.5 litre is a Mitsibushi M.000T81081.
Oil filter part nos as followsmikeonb4c wrote:Anyone know part number for Bongo 2.5 oil filter - want to see if I can get one at local motor factors.
Part number on P1 of this thread is for Bongo 2.0 and mines a 2.5 diesel.
Thanks chums
Blueprint ADC42110
Comline CMB11321
Motaquip VFL 304
AMC MO400
Nipparts J1315005
SK803 (SCT- Germany)
Mann WP928/81
Fram PH6355
oil filters from the following will fit:- Mitsubishi L200 Mitsubishi Shogun 83- 89 2.9TD
compatible relays
Due to spending many hours trying to find a fault that caused all my external lights to work apart from the headlights, i thought i'd let you all know a cheap way of replacing the two relays on the inner wing (passenger side) that illuminate all the external lights. These can be replaced using mazda 626 items which are a straight swap for the bongo items
due to the position of these relays, the rubber jackets that are supposed to protect them actually fill with water & cause the relays to malfunction!!
