Page 2 of 2
Posted: Thu Sep 13, 2007 9:52 am
by dp bradford
daveblueozzie wrote:dp my reversing beep still works without the lights on ,dunno why yours dont.
Hadn't driven after dark for a while until last night - I put it into reverse and nearly jumped out of my skin when it started to beep
Dave
Posted: Thu Sep 13, 2007 5:13 pm
by dovestar
Your not alone db, I have the same problem - cut the white wire, no more door beeps but reverse beep's gone too unless the lights are on.
Not sure how I feel about it, I think I would rather the reverse beeps were always there or not there at all; it's the dithering that gets to me. I’m very happy to have lost the old door beeps though.
Posted: Mon Oct 15, 2007 7:41 pm
by Blue Pearl
brorabongo wrote:Having a lowroof and a manual one at that, I don't suffer from many beeps
but the door open when keys in ignition was a bit annoying. So I just disconnected the white plug under the steering wheel, as can be seen here. The continuous tone for lights left on still works.
STOP THE BEEP
This worked for me, fantastic tip
, as the bongo needs a key in for everything to work, and gets anoying when camping and someone opens a front door. Never had a reversing beep anyway, should I have one in a P reg Manual
Posted: Mon Oct 15, 2007 8:13 pm
by David Edwards
Never had the reverse beeper but as I have a tow bar fitted whenever I am towing and indicate there is a beeping noise sync'd with the indicator.
Posted: Mon Oct 15, 2007 8:38 pm
by David Edwards
Mind having said there is no reverse beeper I have fitted one of the beeping bulbs into the reverse but you would be amazed at how many dozy sods still walk passed as I am reversing even with the beeper and bright bulbs and the dozy old buggers with trolleys at the local supermarket really " do my head in". At least I get some relief when I shout at em " are you sodding deaf as well as blind and stupid " never hAve a bloody gun when yoy need it most do you eh.
