Last trip out this year.
Moderator: Ian
Puma931 wrote:No![]()
Mark Elvin wrote:Did you try loosening off the AFT nuts that hold the brackets to the roof, allows you to lift the rear edge slightly.Puma931 wrote:
Yes, I ordered 8m and fitted it, but got stuck at the back as it was too tight to fit and not enough space to hit with a mallet, so I did not bother with the final part above the tailgate.
http://www.woolies-trim.co.uk/p-1606-fl ... -seal.aspx
