caution on sliding door!!!
aitch
Location: in a place far, far away, well Somerset for now!!!
Post by aitch » Sat May 12, 2007 8:18 pm
my sliding door was a little "sticky" when closing so I sprayed the hinges and runners with WD40. The next time my daughter shut the door it closed very quickly and she nearly trapped her fingers in it!!!
I list this as a caution for all fellow Bongoers as I dont want anybody to get hurt.
p.s. the WD40 worked really well!!!!!!
moonshine
Post by moonshine » Sat May 12, 2007 10:35 pm
My sliding door doesn't actually stick, but sometimes it slides very easily and sometimes it feels like I am opening it against a hydraulic damper. That's the best way I can describe it, as it seems to resist fast movement. Anyone any ideas?
dandywarhol
Post by dandywarhol » Sun May 13, 2007 12:19 am
The hinge pivot which allows it to slide round the corner often gets tight moonshine.
Post by bigdaddycain » Sun May 13, 2007 2:12 am
Thanks for the warning aitch... I'm glad she moved her hand in time :shock:
Am i right in thinking that white grease (lithium?) is the right stuff to use? as with the roof mechanism?
The drawback with WD40 is it attracts a lot of dirt over time, but is great for a quick fix when nothing more suitable is at hand... :wink:
moonshine
Post by moonshine » Sun May 13, 2007 2:55 pm
Thanks Dandy, it's worth a check.
The strange thing is though that sometimes when I open the door it slides back easily and smoothly with just one finger pulling it, but other times it opens easily part way, then requires a hefty shove to go the rest of the way. Just as if it were coming up against a hydraulic damper.
harpo42
Post by harpo42 » Sun May 13, 2007 4:51 pm
When the door is stiff to open have you tried just moving it forward for about 1 or 2 inches and then opening again.
Iv'e noticed that when the weather is wet the door opens easily. The other thing is I too lubricated the door some while ago and now the runners are clogged with dirt which is very difficult to clear out.
Timnz
Post by Timnz » Mon Jun 04, 2007 1:18 am
I noticed this too, actually depending where you park, the van chassis can twist ever so slightly making the sliding door bind a little.
dandywarhol
Post by dandywarhol » Mon Jun 04, 2007 11:29 am
Hmmm....can't agree with that one - I'd say there was more than enough "play" on the hinges and mechanism to allow for any chassis movement - if fact the van would need to be on so rough ground that a wheel was off the deck to "twist" the chassis.......... :shock:
brorabongo
Post by brorabongo » Mon Jun 04, 2007 12:48 pm
moonshine wrote:My sliding door doesn't actually stick, but sometimes it slides very easily and sometimes it feels like I am opening it against a hydraulic damper. That's the best way I can describe it, as it seems to resist fast movement. Anyone any ideas?
I have noticed the same :-k seems totally random.
ボンゴの激怒 pictures
dandywarhol
Post by dandywarhol » Mon Jun 04, 2007 5:39 pm
Squirt some penetrating oil on the hinged part which pivots at the middle (external) runner - it's the pivot pin which usually causes the random tightness.
