Is mine overheating???
maglett
OK, any help would be hugely appreciated.
Nov '06 radiator hose ruptured. All got sorted by the garage. Bongo not used for few months. Drove 600+ miles with no noticable problems, then on arrival home there was bubbling in the expansion tank. Nothing else noticed. Took bongo back to garage, think he treated it as an air lock, sorted out the coolant and squeezed air out of the pipes.
Drove bongo yesterday - 4 miles in bubbling in expansion tank again. No other symptoms noticed. Drove back home slowly - no problems.
Read this forum again!
Just done the following on the driveway:
Coolant level normal.
Ran engine 10 mins approx. Temp gauge 11 o'clock. Hot air blowing from all fans. No bubbling.
Ran engine for ? 8 mins at 2500rpm. Temp gauge gradually rose, then reached HOT, no hot air from internal fan, bubbling started+++, coolant hot, pipe hot, engine fan working fine.
Exhaust fumes clean and dry, no white smoke.
Dropped revs back to normal, everything returned back to normal.
We've had a look at everything under the seats, and there might be a damp patch roughly in line with the gear stick on the drivers side... not sure.
Going to take it back to garage, but any ideas so we have a better understanding/explanation would be appreciated.
maglett
samuraisue
I have just replaced radiator and filled the system and then to ensure I was as safe as possible went onto to bleed and refill. I would recommend that owners who do not own a tecnical handbook pay the $5 for the download from http://www.repairmanual.co.nz. The extra information is well worth the investment.
Now my fingers are crossed that all work has been done correctly! I dread the consequences otherwise.
Nick.
Nick.
maglett
- Peg leg Pete
maglett
Bumbly1
- Peg leg Pete
Veg_Ian
- Peg leg Pete
maglett
BONGO IS BACK!!!
Thermostat was faulty - new one needed fitting.
He followed the instructions for the coolant... apparently a bit of a nightmare!!!
Now Bongo is fine... only tested on 3x 20mile round trips, but no bubbles so far and temp gauge holding at 11 o'clock.
Going to stress it over higher revs for longer duration to check it's really all sorted before I trust it for a proper trip.
Survived in my tent... though didn't sleep very well!
Pete
