Bongo Newbie - Gutter Rail & Fig 8 Query
Moderator: Muzorewa
MargotBongo
Post by MargotBongo » Sun May 04, 2025 4:46 pm
We took our first trip in our 1999 2.5cc petrol Bongo this Easter. We've been committed campers all our adult lives but this is our first campervan - and I cant imagine EVER returning to a tent!
We had planned to get a drive away awning but after thoroughly working through all the threads here on awnings/canopies etc I think our budget will only really stretch to a simple manually attached canopy, which will probably better suit our requirements anyway. However, before we buy I just wanted to check re the Gutter Rails.
Advice here states we'll need to first attach Fig 8 to the van Gutter Rails - are these rails the small channels found on the side of van, as per photo's below?
They seem so shallow - how does a Fig 8 stay on securely?? And how do we actually attach it - does it slide or clip on easily?
Advice here also recommends sourcing a single length of Fig 8, rather than multiple smaller strips. Do they vary in quality? The only place I have found that will deliver a single length is Camper Interiors at a cost of £16.50 plus £13.50 delivery. Does this seem reasonable??
https://camperinteriors.co.uk/products/ ... s=e&_v=1.0
Many thanks
Enjoying The Good Life with Margot our Bongo
Re: Bongo Newbie - Gutter Rail & Fig 8 Query
Post by g8dhe » Sun May 04, 2025 5:14 pm
The fig-of-8 slides on and is normally quite hard to fit the first time as it grips rather well! Many just leave it on permanently especially the long ones!
Some people fit it by putting it to the edge above and then pull it down horizontally causing the outer edge to slide over and underneath.
You can fit shorter lengths but people have reported water leaks when its raining over the door at the joins!
MargotBongo
Post by MargotBongo » Sun May 04, 2025 5:22 pm
Thanks Geoff - and are the rails the small channel things on the side?
Post by Ian » Sun May 04, 2025 6:30 pm
No need to pay that much: https://olproshop.com/figure-of-8-plast ... pack-of-3/
And yes, they fit on the gutters as indicated in your photo
Post by g8dhe » Sun May 04, 2025 6:37 pm
Yes the "rails" are the rain gutters.
James_C
Post by James_C » Tue May 27, 2025 7:59 pm
Hello all,
We're looking to get the same setup - figure of 8 rail and a sun canopy.
I was looking at this one from olpro -
https://olproshop.com/multi-shade-campervan-canopy/
Does anyone have any recommendations for them?
2002 2L 'tin top'
BromGo
Post by BromGo » Tue Jun 17, 2025 6:43 am
We found the “drive away” awning immeasurably irritating to use. The drive away part is fine, it’s the drive back part that is absurd.
Far better for us was a simple tarp and a couple of guy lines pinned the far side of the bongo. Just two lines to slip off their pegs than a whole rather naff figure of 8 to feed in and out whilst slowly manoeuvring vehicle into precise spot from a perfectly parallel angle.
Post by g8dhe » Tue Jun 17, 2025 3:29 pm
? You were using a Kador strip to link the two fig-of-8 strips together?
