Engine swap
Re: Engine swap
there are 2 photos on page 1 of engine and gearbox in once I’ve wired it up and got it running will post more
Re: Engine swap
Seems like Toyota 1uzfe is the engine of choice for a lot of swaps, quite fancy upgrading v6 to v8
Re: Engine swap
That maybe the way forward from a performance point of view I just wanted a solid up to date economical diesel the 5 speed auto box was a bonus
Re: Engine swap
Did you complete the BMW conversion?willow2u wrote: Sun Jul 19, 2020 6:19 pm I’m going bmw you’ve obviously got a petrol mines a Diesel, engine And box is all in still needs all the wiring sorting and exhaust shouldn’t be to much aggro but I’m sorting out rust issues now sills arches etc 489C0D0D-CDFA-45AA-809A-66CC1EEB488B.jpegCBAF2D8D-4A7B-4A4B-9FE6-A851E8294164.jpeg
How did it turn out?
Re: Engine swap
Hi re the BMW swap I pretty much have 95% of the wiring sorted just really the cooling fans and air con fan control to sort. I started it up and everything was good. I’m running the bmw dashboard so will have to run indicator's headlights high beam and a few other controls so I will use the bingo light stalk as the cruise control activator. The welding is all done so next step is bodywork prep for painting it should see the road this summer fingers crossed
cheers
